| Thread Tools |
Rating:
Display Modes |
#91
Re: ANNOUNCING: navX MXP Robotics Navigation Sensor
Ok, so I know that this post is kind of old, but both websites linked said that this item was out of stock. Is there any other place where I can obtain it or the previous model?
#92
1) The pre-built 32-bit binary of navX MXP UI (processing/navXMXPUI/application.windows32) works if 32-bit Java 1.8 is installed, and is the "Active" version of java. 2) The pre-built 64-bit binary of navX MXP UI (processing/navXMXPUI/application.windows64) works if 64-bit Java 1.8 is installed, and is the "Active" version of java. 3) To tell which version of java is currently "Active", open up a command window, and type this command: java -versionHere's what's displayed when the 32-bit version of java is "Active": java version "1.8.0_31"Here's what's displayed when the 64-bit version of java is "Active": java version "1.8.0_31"4) We have not found an easy way to switch the "Active" version of java between the 32 and 64-bit versions of java - but we found online discussions about it. However, since both the 32 and 64-bit pre-built navXMXPUI binaries work w/their respective versions of java, the recommendation is to run the version of navXMXPUI that matches your version of java. 5) We recommend the 64-bit version of the navX MXP UI, since that's the version we test with most often. |
#95
Is anybody here able to guide me through the process of maintaining a fixed header in labview? I'm a bit stuck and trying to follow a guide that isn't meant for this specific gyro. Thanks!
#96
An easy way to do this is to multiply (or divide) the error by a scale factor and wire it to the X axis of an Arcade Drive function. This won't be perfect; it is likely to either oscillate around the desired heading or never quite reach it. That's where a PID function comes in handy, using the Proportional term to turn the robot faster when it's farther off target, and adding in an Integral term to give the turn a little more oomph when it's been off target for too long. A Derivative term is rarely necessary, but might help reduce overshoot if the robot ever gets way off target. |
#97
Update: I've removed the 32 bit JRE and installed the 64 bit JRE 1.8. Everything seems to be working properly.
I'm still digesting the actual navX code. It's not clear to me yet which calculations are being performed in Scott's code vs. what is performed by the DMP. Definitely one of the most complex embedded projects I've encountered; most don't even do floating point math. |
#98
Due to several issues found in the invensense "motion processing library" (MPL), the rest of the work is performed on the very capable STM32F4 processor by Kauai Labs code. After acquiring a quaternion (line 596), this code in MPU9250/mpucontroller.cpp: - transforms the quaternion to yaw/pitch/roll - calculates the gravity vector from the quaternion, and subtracts that from the accelerometer data to yield linear acceleration. - acquires periodic magnetometer samples, time-averaging to reduce noise - applies magnetometer calibration to the raw magnetometer data to get a compass heading - tilt-corrects the compass heading based on the pitch/roll - calculates the "fused (9-axis) heading" from the yaw and the tilt-corrected, calibrated compass heading Then, in the navx-mxp/navx-mxp.cpp nav10_main(), it: - maintains statistics of linear acceleration to detect motion/no-motion - maintains a yaw history, to detect if rotating - if in startup calibration period, and not moving and not rotating, calculates a yaw offset, which is removed from subsequent yaw values - sends out updates, updates registers, and processes inbound requests You'll also come across some work-in-progress code for building and applying a temperature-compensation gyro bias which should someday completely eliminate the automatic gyro calibration after sufficient temp/bias values have been acquired and stored to flash memory. Last edited by slibert : 01-23-2015 at 02:24 PM. |
#99
Any expected delivery date for the CAD files for the enclosure? Or has anyone come up with them on their own?
#100
If anyone has any ideas for the enclosure design, please let us know. We've discussed so far a "lid" that rests atop the navX MXP board, is fastened to the navX MXP and the RoboRio via the two screw holes near the RoboRio USB connector, has two posts which help "grip" the navX MXP from the other end (where the two semi-circular holes are) and has top-side holes for pressing reset/cal button, holes for the LEDs to shine through, and something akin to the CRio's Digital Sidecar plastic shell to help secure PWM connectors that might be connected to the Digital/Analog I/O pins on the navX MXP.... |
#101
I calibrated the magnetometer, but the MAG_DISTURBANCE indicator is constantly on.
Also, if I rotate the robot 180 degrees, the yaw reads 200 degrees. |
#103
So in your case either the magnetic field is truly being disturbed, or the value being used for the magnetic field strength is incorrect. When calibrated at a high quality level, the navX MXP magnetometer is quite sensitive. Simply holding an iphone a few inches away from the navX MXPUI (when the magnetometer calibration is of high quality) is sufficient to trigger a "magnetic disturbance" detection. More often, though, the quality of the calibration is an issue. I have yet to meet anyone who achieves quality magnetic calibration on the first try - indeed it's taken quite some practice for me personally to get quality calibration. Here are some hints to help achieve quality calibration: - Carefully double and triple-check each step along the way - it's very easy to get the orientation of the axes wrong on one or more of the 12 steps. A single error in orientation can lead to low-quality calibration data. - Another important factor to consider is it's very important that there are not *changing* sources of magnetic disturbance during the magnetometer calibration process. We've seen problems when calibrating the magnetometer near a PC, and another time near a USB cable that had a "choke" (a round piece of ferrous metal) on it. If there are any such sources of interference nearby that _are still_, while you _are moving_ the navX MXP to calibrate it, the fluctuations in the magnetic field measured by the navX MXP will lead to errors in the calibration. Regarding the yaw measurement, there's a common cause for the symptom you report. It's very important to ensure that the navX MXP is held still during the startup (calibration) phase in order to get accurate yaw measurements. Please read the gyroscope/accelerometer calibration wiki page for details on this. You can also use the navX MXP UI to see this clearly - when the "Calibrating..." indicator is displayed the navX MXP must be held still. Only after this indicator is removed will yaw measurements exhibit high accuracy. |
#104
Well, the mini USB I was using had a choke, I was calibrating next to a PC, I was also moving during the calibration, and I did all the calibrations by eyeballing it.
It seems reasonable to assume that my calibration sucked ![]() I'll try it again against a fixed corner, attempt to scavenge for another usb, and move my PC far away. |
#105
How likely is it that a mini USB with a choke will screw up the calibration?
That's the only cord I've been able to get my hands on |
