| Thread Tools |
Rating:
Display Modes |
#106
Re: ANNOUNCING: navX MXP Robotics Navigation Sensor
The choke will only cause a problem if it moves. If it stays in the same place during the calibration and while in use, then there should not be a problem. For our calibration w/a choke, I've actually taped it in place to make sure it doesn't cause a problem (moving relative to the navX MXP during calibration).
#107
The STL file is what one would typically use to 3D-print the enclosure. If you want to modify the design, you can use Sketchup 2015 and the STL Import/Export Extension to generate the STL file from that. We're testing this by sending out a order to Sculpteo, they are charging about 10.00 plus 6.00 shipping for a white plastic version (prices increase depending upon the materials and colors chosen). Shapeways charges a similar amount. Last edited by slibert : 02-02-2015 at 12:51 AM. |
#108
[quote=slibert;1437174]A first cut of the Sketchup and STL files for a lid-style enclosure for the navX MXP when mounted on the MXP port of the RoboRio are now available.
There does not appear to be a link to the STL file. Will these be made available for download? |
#109
We have been having some problems with brownouts causing us to lose the NavX. Essentially, if the NavX loses power for even a fraction of a second, the roboRIO loses connection with it and isnt able to reconnect. I have tried to reinstantiate the IMU object, but it seems like FIRST does not want you doing that outside of robotInit. Do you have any solutions to this? I'm not sure how frequent brownouts will be, but 7 volts sounds like something teams will be running into often.
#110
[quote=mklinker;1437227]
Another option you have is to use the "Low Level Connect via Power and Signal pins on MXP connector". In your case, the power could be supplied from a separate 5VDC source. I think the USB cable option indicated above would be simpler. Finally, as to the recovery when the roborio restarts, what language and communication interface are you using? |
#112
Can you explain what you mean by this?
#113
I should probably mention that I am using Java.
In disabledInit(), I called the constructor for IMU if I knew that I lost connection. This caused the RoboRIO to throw a slew of errors related to NI-VISA and HALUTIL. Unfortunately I dont have a log of these errors available to me. On second thought, there is a good chance this was being caused because I had already instantiated the IMU once, and I'm not allowed to access the port twice. Anyways, USB should solve my problems. The 5V rail apparently is supposed to stay alive down until the RoboRIO itself experiences a brownout. |
#114
If the 5V (MXP) rail stays alive until the RoboRio itself experiences a brownout, then the navX MXP should continue to receive 5V and should therefore not reset. It's theoretically possible that the RoboRio has onboard capacitors that allow it to "ride over" a dropout for a longer period of time than the nav MXP's capacitor. However, if this is the case, your RoboRio is already dangerously close to browning out. Are you confident that the navX MXP was being reset due to an undervoltage situation on the RoboRio's 5V MXP Rail? |
#115
Problem, Our Roborio is going to be mounted vertically. What are the implications for the Navx MXP. We are using some of the break out ports and do not want to mount the board off the robo rio.
#116
The navX MXP's motion processing requires the unit be mounted horizontally, parallel to the earth's surface; the implications of non-standard mounting include the invalidation of the assumption that the z-axis is perpendicular to the earths surface. This will cause the MPU-9250 accelerometer self-tests to fail. While the calibrated gyro data should still be usable (as this is unaffected by gravity), the accelerometer data and the fusion of that data with the gyros to derive a yaw angle will all be negatively impacted. It is for these reasons that this approach is discouraged. If you do choose to embark upon this non-standard mounting experiment, please let us know your results. It's possible the navX MXP will generate useful information under these circumstances, though that would seem doubtful based upon the above discussion and some quick experiments here at Kauai Labs. |
#117
Is this a hardware limitation of the MPU-9250? If not, would it be possible in theory to change the firmware either to deduce on powerup which axis is the up/down one, or to accept a configuration instruction describing its mounting orientation?
#118
The MPU-9250 driver includes a orientation matrix that can be sent to the MPU-9250's DMP; this is intended to be used to identify the orientation of the MPU-9250 relative to the circuit board it is mounted on. This could potentially be investigated as a method for allowing alternate mounting configuration of the navX MXP itself. It's theoretically possible to have an advanced configuration option whereby one could specify an alternate mounting configuration. If there's enough interest, we can study this further; such a change would require a non-trivial amount of work and testing. |
#119
I'm looking at the printing the .stl. Can you alter the extruded text on the top of the cover to a cut? This cover is best printed with the top facing down on the bed. Thanks for providing a nice cover!
#120
Hmm, you make a good point about the printing w/the top facing down on the bed. We'll get to work on your suggestion; we're also planning on thickening the edges a bit to enhance durability. This will likely take several days to complete and test, an update will be posted on this thread when the updated .stl is available.
