Thread Tools |
Rating:
Display Modes |
Re: Sparky 384: Custom DS Transmission (2014 Offseason Project)
The additional retaining ring groove in the output shaft gives me the heebie jeebies. That's an immediately obvious, clear point of potential failure, so keep an eye on it.
Im not sure I understand, which specific groove on the output shaft? Why does this worry you? Thanks |
The retaining ring groove, though, is a point of stress concentration in the shaft. You're presumably transmitting torque through the groove -- perhaps to a wheel or set of power transmission components -- and doing so can lead to a failure of the shaft at the groove. |
Looks pretty neat. Is the encoder mount and custom output shaft stuff the only change to the normal WCP gearbox?
No, it isnt. We did base the hole patterns off of the WCP gearbox so that way we can use the same gear ratios available COTS (saves time and money), but some of the geometry is different (the overall dimensions are different and the plates themselves are different). Our custom transmission is shorter and a little bit thicker than the WCP DS. The way our transmission mounts onto the 1" x 2" tubing is also different. The tolerances on the pressed bearings have also been changed to allow for a much better fit (no way those puppies are coming out). Some changes will also be made after kickoff to allow for motors and their pinion gears to be swapped out without having to take apart the transmission (something that is an issue with the WCP gearboxes). If you closely compare the two the differences will start becoming more apparent. Thanks Last edited by Fearthewookie : 03-01-2015 at 07:58. |
I understand what you are saying now. Thank you for your input. |
Im not sure this is common practice either, but due to our modular West Coast style drive rails (our drive system unbolts from the chasis in order to allow for maintenance or emergency swap-outs), our transmissions need to be easily disconnected. We found this is the best and cleanest way to do so. I am including an image of our modular system used at 2014 offseason competitions. The transmission pictured is last years custom one speed. (its beige simply because it was an r&d project). This was taken during a dissassembly to train new members, so the middle wheel is of course missing. Thanks Last edited by Fearthewookie : 02-01-2015 at 22:35. |
Tidy, yes. However, large banks of powerpoles are also much more difficult to plug and unplug.
This can be true but we dont have too many issues with it ourselves (the largest powerpole bank we use is the one you see in the picture). The main problem with those Anderson powerpoles is installation xD They can be a real pain.
