Thread Tools |
Rating:
Display Modes |
Re: 2015 Recycle Rush Scoring
My problem with the golden totes in auton being worth only 2... Grey bins in Teleop are worth only 2. Arent auton scores always worth more?
I don't think you can get Teleop points in auto. What do the rest of yall think? |
Points for gray totes are rewarded at the end of the match.
Grey totes aside, lets look at the gold ones. lets have 0 be a golden tote and ___ be the ground. Ill give you the situations I see happening.
___0___0___0____ =? .....0 ___0________0___=? ...0 ...0 __0________=? How many points would each situation be worth in auton? Would it be 6 (2 points each) on the first, or 18 points, 6 per. Would the second be worth 20+6 (one stack one alone)? 20+2(this would be if scoring totes alone in auton are only worth 2)? Would the last only be worth 20? It seems like quite a feat to get 3 stacked in auton. Im sure we will see it, but it seems insignificant if you look at what you can score after Teleop starts. Last edited by 216Robochick288 : 03-01-2015 at 12:33. Reason: Ugh the dots are ugly but without them it looks awful |
I couldn't find anything in the rules (haven't read entire thing tho), can we open the totes and stack them inside of each other?
G16 Blue Box, Item C.
They are intended to be closed- THey are zip tied shut. |
Please read page 19 of the manual. |
You're forgetting a situation:
......0 ___0 0________ = ? (I believe this is a void configuration resulting in 6pts, however there was not an example given to this situation in the manual.) anyways here is how I see the scoring of the yellow totes alone in their respective situations (assuming they are compleatly contained by the auto zones): ___0___0___0____ = 6pts .....0 ___0________0___= 6pts ...0 ...0 __0________= 20pts (possibly 26, depending is a stack and a set can simultaneously exist) |
#10
A similar situation is called out at the bottom of page 19. They are not in a single column and do not meet point A of being a stack.
#11
Okay, so that is considered a TOTE SET, which is defined by 3 golden totes in the auton area. The CONTAINER SET is the tall recycling bins, NOT the totes. 3 of the large bins in the scoring area count for 8 points. A STACKED TOTE SET are all 3 golden totes stacked on top of each other as per figure 3-1 , or 3.1.2.1 in the rules. It appears, though I may be wrong, that 2 totes or two bins dont count? |
#12
Situation 1 would be worth 6 points, a Tote Set. Situation 2 would be worth 6 points as well, still a Tote set because you need all 3 totes to be stacked to be a Stacked Tote set and worth 20 points. Situation 3 would be worth 20 points, as it is a Stacked Tote set. This requires all of the totes to be stacked in a single stack. See section 3.1.2.1 |
#13
Auto:
Stacked Tote Set = 20 points Container Set = 8 points Robot Set = 4 points Maximum Autonomous points = 32 points Teleop Totes: Alliance Station = 30 totes Landfill = 28 totes Step = 12 totes Maximum amount of totes = 70 totes Maximum tote points (2 points each) = 140 points Teleop Containers: Staging Area = 3 containers Step = 4 containers Maximum amount of containers = 7 containers Maximum container points (4 points each with level 6 multiplier) =168 points Teleop Litter: Litter = 20 total (10 for each alliance) 7 Litter in container (6 points each) = 42 points 13 Litter as unprocessed (4 points each) = 52 points Maximum litter points = 94 points Teleop Coopertition: Coopertition Stack = 40 points Teleop Total: Totes = 140 points Containers = 168 points Litter = 94 points Coopertition = 40 points Total Teleop Points = 442 points Total Auto Points = 32 points Total Points = 474 points Last edited by Brennen3828 : 05-01-2015 at 23:18. |
#14
According to the game reveal video at 1:25 you can move them in auton.
#15
Agreed. It's legal to move them, but you don't get any auto-specific points. If you want to start stacking, though, you're welcome to.
