Go to Post There is nothing that says 'gracious professionalism' like making brunch for your opponents. - Monochron [more]
  #16   Spotlight this post!
Unread 03-01-2015, 13:52
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Rookie Year: 2011
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Re: Compatition Ranking
Originally Posted by Marc P. View Post
I think it is to normalize the "perfect storm" random chance alliances, where 3 super powerful robots are paired by the all mighty randomized partner algorithm. It dilutes that one magic match where the stars align and the score ends up 3 times higher than your other matches, mainly because of a particular mix of robots and not so much the individual robot's performance. The average gives an adjusted and IMO more accurate portrayal of actual robot contribution over multiple matches, rather than cumulative score, where one magic match can boost a team's ranking beyond their typical performance.
Consider this scenario:
Last match of qualifications:
Team A: Average Score:98pts/match
Team B: 100pts/match
Team C: 102pts/match
Team D: 98pts/match
Team E: 100pts/match
Team F: 102pts/match
Seems like a fair match-up right? but the stars align for team A-B-C and...
Final score:A-B-C 300 | D-E-F 100
Even tough these teams were identical in their stats team A-B-C pulled out a significant win. The average scores of team D-E-F stay approximately the same, and while the teams were tied in the standings before this match took place teams A,B, and C are now all ahead of teams D,E, and F.
My point being: since the same number of qualification matches are played (excluding surrogates) why does averaging matter?
  #17   Spotlight this post!
Unread 03-01-2015, 14:36
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
Under this system of averaging, it is easier to compare between events that run different numbers of matches. This could be especially valuable if events within a single district region have to run different numbers of matches.
That's my guess anyway.
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
  #18   Spotlight this post!
Unread 03-01-2015, 15:07
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
Rookie Year: 2011
My updated insight is as follows- the averaging simply allows for an easier way to compare teams that have different number of matches played. For example:
Team A has a QA of 100pts/match and 4 games played
Team B has a QA of 110pts/match and 3 games played
This is a lot easier to compare than
Team A has 400 points total, and 4 games played
Team B has 330 points total, and 3 games played
  #19   Spotlight this post!
Unread 03-01-2015, 16:15
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Originally Posted by XaulZan11 View Post
If that is the reason, why change it now? FIRST has always done total qualification points (or whatever the points were called in 2010).
Perhaps it is a way to normalize scoring across events for district points?
The one nice (depending on your perspective) thing about the old method was more teams got to be in 1st place (or other high ranking spots) for a short while due to the extra noise. Now since everything is normalized, there will be a lot less movement in the rankings. A good thing from a usability standpoint, but not as many teams will get a short-lived boost from seeing their names at the top of the scrolling chart.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
  #20   Spotlight this post!
Unread 05-01-2015, 09:10
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
My big question is if we are taking an AVERAGE score, then why leave out a surrogate match. Why not have that team's average be based on 11 matches instead of 10 (or whatever the case may be)? I can see in a Win/Loss scenario, or even if we were going with total points, but going off an average?
My fear is that teams will adopt the strategy of sabotaging their surrogate matches. If it doesn't count against them, why not lower the other teams' average? Granted, definitely NOT in the spirit of FIRST, but you know teams will do it. If we did away with surrogates this year, and let a few teams have an extra match figured into their average, I don't see where it would hurt.
  #21   Spotlight this post!
Unread 05-01-2015, 09:15
cbudrecki's Avatar
My other question; Is ranking averaged match-by-match as the day goes on, or is it always calculated by the number of matches scheduled?
Example: After 3 matches, a team has 330 points. They are scheduled for 10 Qualifier matches. Is their current average 110 (330/3) or 33 (330/10)?
  #22   Spotlight this post!
Unread 05-01-2015, 09:17
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
I Initially thought it was just to make the ranking nicer to watch, but it appears this doesn't happen...
Section 5.3.3:
Originally Posted by Ye Olde Maual
The total number of MATCH Points earned by a Team throughout their Qualification MATCHES, divided by their number of assigned MATCHES (excluding any SURROGATE MATCHES), then truncated to two decimal places, is their Qualification Average (QA).
The key word is assigned. It does not say matches played at that point.
This leads me to believe that the divisor of the average is constant through the whole event, actually making the whole averaging thing pointless for viewing purposes or... anything... over just a total. This seems really weird though, I'm guessing they don't mean that since, well, it doesn't make any sense.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
  #23   Spotlight this post!
Unread 05-01-2015, 12:14
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Section 5.3.3:
I don't have any special knowledge but I expect the Pit Display will show average score throughout the competition. From a tournament perspective Qualification Average doesn't have any role before final ranking, although in practice we all want to know where we stand throughout the competition.
no stranger to the working end of a pencil
  #24   Spotlight this post!
Unread 05-01-2015, 12:17
MikeE's Avatar
no team (Volunteer)
I hope that District events stay with the standard 12 matches for all teams. This guarantees no surrogates and for smaller events also keeps a feasible inter-match minimum.
  #25   Spotlight this post!
Unread 05-01-2015, 14:17
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
Rookie Year: 2011
You wouldn't want to throw a surrogate match. Not all teams look closely enough while scouting to realize that a team is playing a surrogate match. A bad performance in match number 4 (typically where surrogate matches are inserted) may put the team that might want to pick them in a position where they said "But they did terrible in match Number 4". And thus may not consider picking the team when Saturday afternoon comes around.
