WPILIB C++ Documentation
Does anybody know where the documentation is for the 2015 WPILIB C++? I cn only see the 2014 so far when doing Google searches. Although it will be really similar, there must be new documentation somewhere, right?
John |
Re: WPILIB C++ Documentation
I think this might help. https://wpilib.screenstepslive.com/s...eclipse-c-java
It can be found at http://first.wpi.edu/FRC/roborio/release/docs/cpp/
We are wondering about this as well. We had no trouble finding the online documentation but we used to get a local copy of the WPILib documentation (as well as a copy of the source code) when we installed the WPILib updates. Now the documentation only appears to be available online and we have not found a convenient way to grab a local copy... and we do not appear to have access to the source code at all (only header files).
In addition we have just noticed that we cannot have the WiFi connect while connecting the the roboRIO over ethernet. This causes a conflict in being able to view documentation and program the roboRIO on a laptop. Hopefully they will fix this soon by making a soft copy of the Doxygen documentation available as a pdf or similar that can be hosted locally on a laptop. |
I remember reading a note somewhere in the online documentation saying they haven't created the 2015 Windows help file yet and they hoped to get it out in one of the updates.
Is there an update on this? My team has a copy of the docs but the search functionality doesn't work correctly for whatever reason.
We managed to get both working at the same time if we connect to the wi-fi network after we connect to the roboRIO. I don't think it matters, but the computer was plugged into the radio, not directly into the roboRIO.
Sorry. I mis-spoke. I meant when connected to the roboRIO through the wireless (as opposed to the USB). But thanks for that update.
I generated a copy and posted a zip file of the .chm file. Look for the second .zip file in this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=133453 |
