Go to Post "What connection is the most vital to the success of your robot?" The one between the drivers brain and hands, and the one between the coaches brain and mouth. None of the other ones matter if those two don't work. - dlavery [more]
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Unread 03-01-2015, 15:33
pbhead pbhead is offline
FTC #1123
pbhead is just really nicepbhead is just really nicepbhead is just really nicepbhead is just really nicepbhead is just really nice
The Noodle Agreement
Not to be confused with the noodle incident.
The noodle agreement is an exploitation of the tournament rules and scoring system, in that QA score is based upon maximum score alone, and G24 prohibits robots from throwing game objects to the other side of the field.
For effectively zero effort, both alliances can score the other alliance 40 points by simply dropping their noodles (litter) on the floor outside the player station. It is a huge net benefit to both alliances, for both the points, and no longer having to worry about noodles getting tossed into locations which could tangle on their robots.
And since the herculean task of putting a noodle into a trash can earns but 2 more points above the noodle agreement, there is very little incentive to spend time/effort/weight to attempt to accomplish the task.
It does mean one of the player stations will be cluttered with noodles, but the asymmetry of the map means one player station is better used than the other anyway. Good teams will also be able to minimize the quantity of time the station is cluttered by rapidly deploying the noodles near the end of the game.
But effectively, if the 6 teams on both alliances agree to do the noodle agreement will have almost a 40 point lead above any two alliances which fail to honor the noodle agreement.
Thoughts on the matter?
Persons attempting to find a motive in this narrative will be prosecuted;
persons attempting to find a moral in it will be banished;
persons attempting to find a plot in it will be shot.
By Order of the Author -Mark Twain
Unread 03-01-2015, 15:37
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Rookie Year: 2011
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Re: The Noodle Agreement
Simply Brilliant Sir!
Unread 03-01-2015, 15:41
KevinG KevinG is offline
Chesapeake LRI/Friendly Giant
AKA: Kevin
FRC #3650 (RoboRaptors)
Rookie Year: 1998
KevinG is just really niceKevinG is just really niceKevinG is just really niceKevinG is just really nice
The counter is that both sides have to agree to it, and trust them to follow through. If one team does it and the other doesn't (or puts them in the landfill) it's advantageous. Basically a nerd version of the Prisoner's Dilemma.
Unread 03-01-2015, 15:38
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
Thought of this almost immediately, and it seems like a mutually beneficial arrangement.
I also cant think of a way to restrict teams from doing this, because teams will inevitably drop noodles on their own side while attempting to throw them over the center into their opponents side.
Member 846 Funky Monkeys 2007-2011
Mentor 558 Robosquad 2012
Mentor 846 Funky Monkeys 2011-Present
http://www.becauserobots.org
Man is a robot with Defects
Unread 03-01-2015, 15:42
hexane hexane is offline
Assistant Project Manager (Student)
AKA: Colin
FRC #2062 (C.O.R.E. 2062)
Team Role: Mechanical
Rookie Year: 2012
hexane is a glorious beacon of lighthexane is a glorious beacon of lighthexane is a glorious beacon of lighthexane is a glorious beacon of lighthexane is a glorious beacon of light
This is a form of Prisoner's Dilemma.
The problem with the agreement is that it is beneficial for any individual alliance to deposit their noodles for the 10 points, meaning that one alliance gets 50 points and the other gets 0. This way, unless you can trust your opponent, it is in your best interest to deposit the noodles.
What do you mean, "our code is too complex?"
Unread 03-01-2015, 15:45
Chinmay's Avatar
im interested to see how this and how coopertition works in elims
Unread 03-01-2015, 15:52
AKA: Colin
Rookie Year: 2012
Coopertition doesn't work in Eliminations. No points are awarded. I assume that this won't happen either.
Unread 03-01-2015, 15:58
Chinmay's Avatar
Just checked the manual and I think I'm missing the rule that says this. Can you let me know what rule number it is.
I had just assumed it worked in quarters and semis because i didn't see anything when I skimmed. I'm sure you're right
FTC #1123
Yes. exactly.
And while coopertition earns a mere 20 points for a fairly difficult task of stacking 4 boxes, this earns 40 points for much less effort.
Unread 03-01-2015, 16:00
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
Originally Posted by pbhead View Post
Yes. exactly.
Coopertition is 40pts for a stack [1.1, table 1-2]
1.1, just under table 1-2
Unread 03-01-2015, 16:05
Chinmay's Avatar
Thanks! I was looking at section 5 trying to find a rule specific to elims
Unread 03-01-2015, 16:16
Jonathan Norris Jonathan Norris is online now
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Reading through the rules this came up as a HUGE red flag for me... With how eliminations are structured this year, teams can game this system to try and knock off the top alliances in the quarters/semis, 40 points for noodles on the ground is very substantial. The lower/middle tier alliances can stick to the noodle agreement when playing each other, but not against the top alliance or two. I can see a situation where the middle alliances have a massive advantage in this playoff format.
Unfortunately this game gives too much power to the opposing alliance to prevent coopertition scoring, its almost human nature to try and help the underdog teams rank higher then powerhouse teams, there are 80 potential coopertition points to be denied by not cooperating (not sharing a yellow tote for coopertition stacks, and the noodle agreement). As much as this game tries not to be a competition, there is still a winner.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 03-01-2015, 16:38
Verrazano Verrazano is offline
FRC #3512
Verrazano is an unknown quantity at this point
Even though it seems like a prisoners dilemma I don't think it is. If alliances say they will do the noodle agreement. And then one team/alliance doesn't then I think there will be serious repercussions, people would stop doing the noodle agreement with them meaning they wouldn't get their 40 points after the screwed another alliance. Also who would want to pick a team like that for elims? My team puts a lot of weight on how our teams work together when picking an alliance partner. Why would you pick a team that doesn't listen or lies.
Unread 03-01-2015, 16:44
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
Team Role: Coach
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
My initial thoughts on how to make this work. You agree to the noodle agreement with the terms that you throw one noodle at a time. Alliance a throws one noodle and then alliance b throws another and back and forth. If one alliance stops, so does the other.
I really hope first gives an update that makes this not okay somehow.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
  #15   Spotlight this post!
Unread 03-01-2015, 16:46
Chinmay's Avatar
Any thoughts on how they would hypothetically make it work? I'm struggling to come up with a solution that works... even if they were to hypothetically introduce red and blue noodles that are alliance specific
