Go to Post This isn't just a robot competition, it's not robots driving robots. It's people driving robots, and teams of people who have put a lot into making the robots work. - Gadget470 [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.50 average. Display Modes
Unread 03-01-2015, 16:12
Dentyne_Ice97 Dentyne_Ice97 is offline
FRC #3965
Dentyne_Ice97 is an unknown quantity at this point
Recycle bin score
Will the green recycle bins be scored if they are placed above level 6?
Unread 03-01-2015, 16:13
ATannahill ATannahill is online now
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
Re: Recycle bin score
As I take it level 6 has no upper limit as signified by the arrow on Figure 3-4. This seems to be a question for the Q&A.
Unread 03-01-2015, 16:15
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
Assuming level 6 ends at the top of the backstop, my reading is no, since no part of the recycling bin would be in level 6. However, I can't find anything that indicates where level 6 ends, so perhaps level 6 extends indefinitely upwards.
Edit: I think rtfgnow is correct, and that level 6 extends indefinitely upwards.
Unread 03-01-2015, 16:16
FRC #3965
What I meant is if you have 6 gray bins stacked and one green recycle on top of that will you receive points for that green recycle bin?
Unread 03-01-2015, 16:19
AKA: Alex Tannahill
As I imagine it* the top of the sixth tote and the bottom of the container would be in level six but below the top of the backstop. I do not believe anyone at this time would disagree that it is a level 6 (24 point) score.
*I have no totes or backstops in my apartment (yet), so I cannot say this with any certainty.
Unread 03-01-2015, 16:20
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You should. The bottom of the bin is in Level 6.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Jared's Avatar
Jared Jared is offline
Rookie Year: 2012
Jared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond reputeJared has a reputation beyond repute
To be scored, green recycling containers need to be on SCORED gray bins, which must be under the backstop thing.
Unread 03-01-2015, 16:27
rich2202 rich2202 is online now
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
per 3.1.2.3 - the maximum height of the totes are 6. So, you can't put a container above level 6 (height measured from the bottom of the container).
There is no maximum height for the recycling container.
Unread 03-01-2015, 16:31
AKA: Alex Tannahill
I do not see where in that sections it states the maximum height is 6. I also don't know what units you are using on 6.
To be scored, the gray tote must not be above (even partially) the back stop, which has a height of 6'6".
To be scored, the container must be supported by scored gray totes. This means the container must be on a gray tote that is no more than 6'6" off the ground.
Unread 03-01-2015, 18:10
stryker0603 stryker0603 is offline
AKA: Jordan Smith
FRC #0314 (Megatron Oracles)
stryker0603 will become famous soon enoughstryker0603 will become famous soon enough
The max is 6 because the dimension for height the manual gives is 12.1 inches (Section 2.3.1). Math tells us then that the maximum grey totes you can stack is 6 and still legally stack the recycling container.
Unread 03-01-2015, 18:44
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
How does math tell us that the maximum height is 6? The maximum robot height is about 6 containers; however, there is no rule that you can't carry totes past a height of 6. Is it wise to do so? That's your call.
Edit additions:
Originally Posted by 3.1.2.3 TELEOP SCORING
TOTES
A Gray TOTE is scored if it is fully supported by a SCORING PLATFORM and no portion of the TOTE extends above the top of the
BACKSTOP.
There's no reason to stack past 6 totes, but there is no restriction saying you can't do it.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 03-01-2015, 18:55
RockerRobot's Avatar
RockerRobot RockerRobot is offline
AKA: Annabelle Noland
FRC #3021 (The Agency)
Team Role: Mechanical
Rookie Year: 2013
RockerRobot is an unknown quantity at this point
Anything above level 6 will have the same points as if they were at level 6
Unread 03-01-2015, 19:12
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Levels have no bearing.
Any tote that is sticking above the 6'6" top of the Backstop will be worth zero points. 3.1.2.3, first paragraph.
Past teams:
Unread 03-01-2015, 19:19
theCADguy's Avatar
theCADguy theCADguy is offline
Design Team Student Leader
AKA: Sean Gibbons
FRC #0020 (The Rocketeers)
Team Role: CAD
Rookie Year: 2013
theCADguy has a spectacular aura abouttheCADguy has a spectacular aura about
Since under 3.1.2.3, totes can't be higher than the backstop, the bottom of the bin cannot possibly be above level 6. However, it would only be logical to mark a level 6 if and only if the bin can be scored at that level (since levels only apply to the bin), but this requires the top of the bin to be above the top of the backstop. So therefore, we should be able to legally stack 5 totes and a bin, but I would Q/A it to be completely sure.
  #15   Spotlight this post!
Unread 03-01-2015, 19:28
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
Rookie Year: 2011
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
false you can always stack from the bottom by just picking up the totes and kicking the totes under, but yes it is useless to proceed six totes
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
