Go to Post The students who benefit from FIRST are the real "trophies". - David Brinza [more]
Unread 01-03-2015, 05:26 PM
FleventyFive FleventyFive is offline
FRC #4118
FleventyFive is on a distinguished road
How to run FRCSim on non-Ubuntu linux distro
I just got FRCsim working on my Linux Mint PC. The install script warns you that distributions other than Ubuntu are not supported, but I suspected that it would work fine on most Debian bassed distros. I made these changes to the install script so it will atleast finish running on any linux distro, though FRCsim might fail on some still.
change line 92 to
Code:
if ! echo "deb http://packages.osrfoundation.org/gazebo/ubuntu trusty main" > /etc/apt/sources.list.d/gazebo-latest.list
and line 107 to
Code:
    if ! echo "deb http://first.wpi.edu/FRC/roborio/release/linux trusty main" > /etc/apt/sources.list.d/frcsim-latest.list
This just grabs the repositories for Ubuntu. Instead of trying to find the repo for your distribution
Have fun!
Unread 01-07-2015, 01:56 AM
sgosiaco sgosiaco is offline
FRC #5107
sgosiaco is an unknown quantity at this point
Re: How to run FRCSim on non-Ubuntu linux distro
I ran into an error with the gazebo package. They have packages for more distros that the frcsim does. Specifically they have precise, quantal, raring, saucy and trusty and frcsim only has trusty. So I would recommend not changing line 92 and only changing line 107.
Unread 01-15-2015, 03:28 PM
jman1783 jman1783 is offline
FRC #2900 (Mighty Penguins)
Rookie Year: 1999
jman1783 is an unknown quantity at this point
Interesting. I have only tried on Ubuntu 14.04 64-bit, so I can't confirm or deny that this works. I know that WPI and OSRF are only working on Ubuntu 14.04 for this preliminary roll-out, though.
"Just remember - whether you think you can or you think you can't, you're right." -Stewart Gilligan Griffin
