Clarification on New Bumper Rules and Reusing Them
My team (5241) is a sophomore team, and so we have come to face the reuse or not to reuse dilemma. I believe my team's robot should have bumpers, as we had several issues last year with the battery being disconnected by a hard bump (our old chassis was dented).
When I was searching these forums for information on reusing parts, there was one particular thread (link) which had several users comment on how the part could be reused because the bumper could possibly be considered not part of the robot. Now that the bumpers are optional and considered to be part of the robot's perimeter, would that mean that the bumpers could definitely NOT be reused? Any help would be greatly appreciated. |
Re: Clarification on New Bumper Rules and Reusing Them
There is a blue box on Page 30 of the manual that explains the role bumpers have on Recycle Rush robots.
It is illegal now, as it is now a part that should be bagged with the robot if it is used.
There is no requirement that bumpers be bagged with a ROBOT; although any bumpers not bagged now count toward the withholding allowance.
See the last blue box of Section 4.1.
From R12's blue clarification box,
Personally, I think you're in a grey enough area to be safe; but if you ask for official clarification, it's my belief that you'd get an answer contrary to the one you're looking for. |
...meaning it is a normal part. When I said 'should,' I should have mentioned the withholding allowance.
Thanks for the quick responses, everyone. I think I'll just drop bumpers from the conversation, since I didn't get the idea that I could convince my teammates that they were necessary anyway. We have better things to worry about, like building a fresh chassis (for some reason, we were under the impression they could be used wholesale and did not prepare any materials to build a new one.)
On a related note, the rules I believe still stated that the team numbers had to be displayed? Does anyone have any suggestions for mounting numbers to a raw chassis? |
Once again, I'm flashing back to Stack Attack. Bumpers were introduced after I graduated (2006) and I can't make a convincing argument supporting whether you should or should not use these protective cushions. The 28"x42" perimeter constraint only applies when transporting your robot so if you want to use them, go nuts
#12
I think the bumpers are really your own choice, but you will have to factor in the added size and weight to your robot since they count in those now
#13
Now, the suggestions: First, print a sample out on paper. Then laminate the paper (use a matte finish if you can, those lights are bright down there!). That'll provide some protection for the paper. Attach the number to, not the chassis/drivetrain, but the superstructure. Just to pick on my old team (and one of my best friends), http://www.chiefdelphi.com/media/photos/24201 is a prime example of this method (as is http://www.chiefdelphi.com/media/photos/21476, from the year before). Look at the sponsor labels--those are all laminated paper. Just don't use the same color scheme for the numbers we did, use the current legal one. I want to say that double-stick tape was involved in the attachment of those labels. |
#14
Also note the change in the robot numbering too (The license plate)! Old bumpers if allowed (I don't think under that rule set it will be, once you properly post that question to the Q&A and receive your answer though), would still need to be modified to black #'s of the proper size spacing & stroke on a white background under the 2015 ruleset.
But you should still post the question (there may be others thinking along those very same lines...The Q&A is the proper place to get the answer instead of CD). |
#15
I don't think there has been a year when we could have reused last year's bumper. The robot design changed a lot with each challenge.
I might suggest to the team to just attach pool noodles directly to the frame. That gives you most of the protection with minimal weight. |
