Re: Which controler for driving mecanum?
http://www.chiefdelphi.com/forums/sh...4&postcount=13 Ask for further explanation if needed. |
Our team has used an xbox controller for all of our functions with one driver since at least 2011. 3 of the years we used mecanum and we would have the left joystick/gamepad control forward-back and side-side sliding motion. We then would use the 2 triggers to control an angular turn around the center of our chassis. This was REALLY easy to use and I was able to drive like a pro my first time with the robot on the ground.
We use 2 joysticks. One for each side of the robot like tank drive. However we use the sum of x axis as the strafe. To rotate you just have a difference in y axis.
We also have an option to divide both axis inputs from the joysticks by 2 to give more careful fine control when pressing the triggers. Last edited by matthewdenny : 18-01-2015 at 07:38. |
