Go to Post I'll try to sum up the icon and compile thing quickly so as not to interrupt the design of SkyNet. - Greg McKaskle [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 03-01-2015, 21:49
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
2015 New/Changed ROBOT Rules
The purpose of this thread is to track/discuss which ROBOT rules differ from the 2014 ROBOT rules or are new this season.
  • R2: Team Numbers are no longer required to be displayed on bumpers.
  • R3: New sizing criteria for the second time in 3 seasons.
  • R4: Any bumpers are now count toward the ROBOT weight.
  • R8 Blue Box H and I: Mercury contacts and voltages over 24v are expressly listed as unsafe.
  • R10 Blue Box EXAMPLE 3: Added to clarify wheels that are commonly used in sets of four can be costed individually.
  • R12: COTS Electrical Components with connectors are exempted from reuse restrictions.
  • R18: With the exception of CIM motors, all FRC legal motors are allowed in unlimited quantities.
  • R20: In addition to listing part numbers, specifications for legal FRC batteries are given.
  • R21: (Finally) extra batteries not being used for power are explicitly disallowed.
  • R25: Other Anderson SB connectors besides the SB50 are allowed.
  • R31: Controller power change due to new control system.
  • R32: Radio power change due to new control system.
  • R33: Power requirement of new control system.
  • R36: Fuse replacement of new PDP.
  • R37: Limits for PCMs/VRMs into main WAGO connectors on PDP.
  • R41 A: Victor SP and Talon SRX are legal motor controllers.
  • R41 C: PCM is a legal pneumatics controller.
  • R45: The cRIO is not a legal robot controller.
  • R54: Two ROBOT signal lights are allowed (at least one is required as in the past).
  • R55: "Gluing" is not an example of modifying control system components.
  • R55 G: "Thermal interface material" is exempted from restrictions on modifying control system components.
  • R58 B & C: Motors and servos can only be controlled by passive or approved active MXP devices.
  • R60: The PCM must be controlled over CAN.
  • R61: The PDP must be on the CAN bus. Thus, all teams are required to use CAN.
  • R62: The roboRIO must be on the CAN bus and be able to exercise exclusive control over all CAN devices.
  • R66 I: White Clippard Tanks are not legal.
  • R77: The specified Nason pressure switch must be used.
I think that's everything. The most interesting changes, to me, are R18: ((mostly) unlimited* motors! ), R55 (does this mean hot glue is allowed to secure connections?), and R77 (Those pressure switches are notorious for being inconsistent.)
*Of course, motors are heavy, and your robot still needs to weigh less than 120 lbs.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 03-01-2015, 21:51
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Re: 2015 New/Changed ROBOT Rules
You forgot one of the most important rule changes: The omission of bumper rules entirely. Any bumpers built need to fit in the height and weight restriction like any other robot part, and there is no requirement.
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Rookie Year: 2012
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Thanks for putting this together. R66 is interesting, too - I guess too many of them exploded.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 03-01-2015, 21:59
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
I want to add R4. The optional bumpers are included in the 120lb weight limit.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 03-01-2015, 23:03
cgmv123's Avatar
AKA: Max Vrany
Rookie Year: 2011
The tanks no longer being legal was going to happen sooner or later, especially with other available tanks being equivalent or superior. (And of course, safer).
Unread 03-01-2015, 23:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I just hope the inspectors do not insist that we remove our white non-Clippard tanks like they did last year...
Unread 03-01-2015, 23:29
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
Team Role: Coach
Rookie Year: 2011
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
You have been allowed to use as many signal lights as you wanted even though it wasn't really something most teams did, our team has used two the past two years for a "headlight", but now you can only use up to two.
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 04-01-2015, 00:46
TheHolyHades1 TheHolyHades1 is offline
Rookie Year: 2010
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
If I am reading the rules right, we seem to be able to build a robot which extends to any size/shape during gameplay, provided that it stays within safety rules and is under the 78" height limit, and that it packs down to the required size when transporting?
Unread 04-01-2015, 00:48
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Yes. You are reading that right.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 04-01-2015, 00:58
Rookie Year: 2012
Additionally, it should be able to transform between the transportation configuration and match configuration in less than 60 seconds.
Unread 04-01-2015, 01:02
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
I would call out R3 (or the associated rule) as specifically stating that there are no length and width restrictions, only a height restriction.
Unread 04-01-2015, 01:07
Unsung FIRST Hero
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Rookie Year: 1996
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
When stuff like this happens, you should bring it to the LRI's attention. The LRI is responsible for resolving these issues but only if He/She knows about it.
Ed Sparks
MECH TECH FRC-3959
Unread 04-01-2015, 02:06
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
These robot rules are Old School. I like Old School.
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
