Thread Tools |
Rating:
Display Modes |
Interestingly enough, there's a very specific rule on how you put totes in the chute. You cannot apply any sort of force to the tote, it has to slide, and also when putting it into the chute both hands must be on the chute. You cannot have one hand on the door area and one on the chute, you'll get a foul.
Re: Human Player handling of totes and litter
I can.
OK, I think I see what happened. The poster mixed up the words "chute" and "tote" in a couple places.
For example, you don't have to have 2 hands on the chute. (Nor 2 hands on the tote for that matter.) And you can touch both the chute and the door at the same time. |
Does that not count as "contact" as per rule G6? But, I guess that's what the Q&A is for.
It is good that I am re-reading this and having this in mind to tell my team.
Now I can be sure we don't have any fouls on our team, because I know there is going to be a lot of fouls given for that rule. Not every single person read that rule. |
That Tote is huge...Robots are huge...Robots can move fast....Hands are very special....You like your hands....FIRST and the rest of us want to see that you keep your hands....Therefore, do as was designed. Insert the Tote into the Tote chute....Tap it (the rear of the Tote), against the Tote chute door once. Then move your hands fully away from the Tote and use one hand to lift the handle for the Tote Chute Door and allow the TOTE only by gravity feed to slide into the Field area. (Please DO NOT attempt to use Litter please for a non-intended purpose as, IF you contact both the Tote in the chute, and the Chute Door Handle at the same time, you will incur a G6 Penalty, and your Alliance Partners will not be very happy with you).
G6 A single ALLIANCE member may not be in contact with both a TOTE and the CHUTE DOOR simultaneously. VIOLATION: FOUL. Contact with, both at the same time...key words. What you described=G6. That is how you will keep your hands safe....Now, PLEASE GO WATCH THE VIDEO! Here is the link to the field tour video: https://www.youtube.com/watch?v=9sryrCE4mAo. This should give you a visual illustration of how the totes are suppose to be entered into the playing field. |
#10
Why do you only count two human players? There is one per team, therefore three per alliance. One in each feeder station, and one that can roam. I would assume he (or she) would feed noodles and totes to the two in the feeder stations. |
