Go to Post What are you people going to rumor mill about if we ever actually get a water game? - Kevin Sevcik [more]
Thread Tools Rating: Thread Rating: 19 votes, 5.00 average. Display Modes
Unread 01-04-2015, 10:11 AM
DarthCoder DarthCoder is offline
FRC #4309
DarthCoder is an unknown quantity at this point
Errors with install of Eclipse
I followed the manual on screensteps about how to install Eclipse and the FRC 2015 Toolchains. I've got them installed, and when I compile a sample program it always generates the FRCUserProgram.out file just fine. However, I keep getting two errors: Program "g++" not found in PATH and Program "gcc" not found in PATH. Does anyone know how to get rid of these errors?
Unread 01-04-2015, 10:43 AM
nandeeka's Avatar
nandeeka nandeeka is offline
FRC #1868
Rookie Year: 2013
nandeeka is on a distinguished road
Re: Errors with install of Eclipse
Try looking at this stackoverflow thread.
Unread 01-04-2015, 10:49 AM
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
you need to add the g++ compiler to the PATH
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 01-04-2015, 11:01 AM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Try uninstalling the toolchains, reboot, make sure that the toolchain installer is on your root drive, install the toolchains, then open Eclipse.
Unread 01-04-2015, 11:53 AM
FRC #4309
All right. It works now. Thanks for the help!
Unread 01-04-2015, 03:02 PM
DavisC DavisC is offline
FRC #0539 (Titans)
Rookie Year: 2010
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Just for so others know cause I just spent enough time trying things, what worked for me was:
download minGW (http://sourceforge.net/projects/ming...e=typ_redirect) and put it on the c drive (you only have to install the c++ gcc option when it asks you).
Add the bin folder in minGW to the environmental variable named path.
Open Eclipse and the error messages were gone!
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 01-04-2015, 05:39 PM
djdesjardins djdesjardins is offline
FRC #2451
djdesjardins is an unknown quantity at this point
Tried both suggestions posted here, still getting same error. Anyone fix this in another way?
Unread 01-04-2015, 06:13 PM
FRC #4309
I used the mingw installer and added to the path also. I've heard from some places that going to Window->Preferences->C/C++->Build->Settings and then using Restore Defaults on the Discovery tab can help. Also, if you've changed your PATH you need to restart Eclipse for it to see.
Unread 01-04-2015, 07:14 PM
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Thanks for the guidance on this thread. Having the same problems on Windows 8 after following the instructions, I think. I'm a little mystified about how having the _windows_ mingw toolchain installed (which would logically compile to x86 code) would help with the ARM toolchain needed for the roboRIO. Tried uninstalling the FRC toolchain AND the Eclipse FRC extensions, then re-installing both. No joy.
Unread 01-04-2015, 07:56 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Note: This should not cause any errors if you are only doing FRC dev.
You can safely ignore them. If you are doing more than FRC dev, install G++ on your path via MinGW as already suggested.
Having said that, you can make them go away by prefixing the value listed in the error with "arm-frc-linux-gnueabi-". I'm afraid I don't remember where it is off the top of my head but can provide the exact value if you copy-paste the entire error.
The cause is eclipse CDT (C/C++ Developer tools) expects `g++` to be on the PATH for global header parsing. However the FRC projects use their own version of g++ with a different name (arm-frc-linux-gnueabi-g++) and the global tools don't realize it. It is only a problem if you are doing native development.
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 01-05-2015, 12:02 AM
lbarello lbarello is offline
None #0492
lbarello is an unknown quantity at this point
Somewhere in settings you need to tell Eclipse that the tool path is "c:\frc\bin" (or put it on the path). Once I added that I was able to build a sample robot.
However, the libstdc++.so.6 library is missing. so the link step fails. Actually it is in the WPI toolset, but the linker never sees it. Any ideas? Must be another path somewhere I need to update.
Unread 01-05-2015, 07:50 AM
That warning is expected and can be safely ignored per this page: http://wpilib.screenstepslive.com/s/...to-the-roborio
Unread 01-05-2015, 03:21 PM
FRC #3045
Thanks - did try installing MinGW (did so) and adding c:\MinGW\bin\ to the path variable. Still didn't fix that error. Good to know the libstdc++ error can be ignored, but would be nicer to not have the distraction for myself or team programmers. Continued guidance welcome.
Unread 01-05-2015, 04:30 PM
FRC #4309
Just in case anyone is having problems with the install, I actually wrote an automated installer for my own team. It needs the x86 JDK to be installed, cause it's the 32 bit version of Eclipse for now, but it should get you the up and running at least.
http://botsmiths.org/index.php/botne...auto-installer
  #15   Spotlight this post!
Unread 01-06-2015, 08:18 PM
WhipeeDip WhipeeDip is offline
Programmer
AKA: Elliot
FRC #4139 (Easy as Pi)
Rookie Year: 2013
WhipeeDip is an unknown quantity at this point
Any word on this? I've installed Eclipse and the FRC Toolchain but I'm still getting the g++ and gcc not found in PATH error. It's added to my PATH. I've tried setting defaults, and everything listed in that stackoverflow thread. Still getting the same error.
