Go to Post Solutions are more likely to be implemented if you provide the solution along with the concern! - Jessica Boucher [more]
Unread 04-01-2015, 13:17
prachinawathe15 prachinawathe15 is offline
FRC #1351 (TKO)
Team Role: Leadership
Rookie Year: 2011
prachinawathe15 is an unknown quantity at this point
Encompassing Totes vs. Holding Them Outside Perimeter
Hello everyone,
Our team has been debating back and forth on whether to encompass the totes while we are stacking.
One idea was to keep everything outside the chassis, which would be more difficult for EVOM, but much easier on the chassis people since there would be no major edits to the chassis. Another was to have a U shaped chassis, that would encompass more than half of the tote, if the tote was being held the long way, but that would require a major chassis edit and changes to electronics that may lead to major setbacks.
What are your thoughts on how to hold the totes relative to the chassis? We would love to have your input on this dilemma
Unread 04-01-2015, 13:20
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Re: Encompassing Totes vs. Holding Them Outside Perimeter
The driving factor in this debate should be less whether or not it annoys your design team, and more based on how important co-op stacking is. Every other kind of stacking is possible with both designs, but you can't drive over the step.
Unread 04-01-2015, 13:21
Whippet's Avatar
Whippet Whippet is online now
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
I think the best option for your team would be to look at whether or not the center of mass offset provided by moving the tote inside your frame is worth the extra work based on your strategy. If you want it to be that much harder for you to tip over, then go for it! Otherwise, you might be better off allocating your resources elsewhere. There is no "incorrect" way of completing this challenge (unless it violates the rules.)
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Did you already build your chassis and electronics before you knew what your robot would be doing?
As far as deciding where to put totes,consider the weight of a stack of totes and where that weight will be relative to your C.G. and relative to where your wheels touch the floor.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 04-01-2015, 13:23
FRC #1351 (TKO)
Rookie Year: 2011
Agreed. We did discuss this, and do have a way for either design to do co-op.
Unread 04-01-2015, 13:27
FRC #1351 (TKO)
Rookie Year: 2011
We had planned a West Coast chassis and have a standardized e-plate design. Before the West Coast chassis was introduced, we had a standardized chassis that we used for the two years before that (2013-2014). We have historically been a strong defensive robot, so this is definitely a new challenge for us--chassis has always been pretty much the same, so we aren't sure if making this change will allow us to finish on time.
That being said, we will definitely have to calculate how much the center of gravity will be offset dependent on where the boxes are held relative to the chassis.
