Go to Post Without fail, judges always come by when the spokespeople are in the bathroom, so others should be able to cover until they're back. - Jacob Bendicksen [more]
Go Back   Chief Delphi > Old Forum Archives > 2001
Unread 24-06-2002, 02:15
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
pressure sensors
Posted by Patrick Butler at 03/13/2001 10:06 PM EST
Student on team #122, NASA Knights, from NHGS and NASA Langley Research Center.
Did any of the balance-bots(bridge manipulators) use pressure sensors to detect if the bridge is balanced? Maybe modification of the pnuematics pressure valve could be used. i.e. check the pressure if it is greater than some value there is pressure, this would in essence create a sensor that is variable?
I know it's a little after the fact but I want to know what cool things people have done that might help us out . Our bot doesn't have these abilities so we don't have any of these features but they were some things which I thought up a while ago, and since I have only recently joined the forum wanted to ask about them . . .
Patrik
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
Robotics Tournament at Sensors Expo & Conference Kyle Fenton Off-Season Events 4 04-05-2003 12:15
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
