Need Help With Mecanum Code
Okay, what we're trying to do is to, through LabVIEW, programmatically make a robot with a mecanum drivetrain drive "smoothly." We will be using PID, a gyro, and a Nav6 sensor. Any help will be appreciated. We encourage adding code examples in your answers.
Thank you! |
Re: Need Help With Mecanum Code
Don't try to fix poor craftsmanship with software. http://www.chiefdelphi.com/forums/sh...3&postcount=41 |
In that case, please describe the difference between what it currently does and what you want it to do.
What is the difference between driving smoothly and "smoothly"? Please describe any sensors you have mounted, any data you've gathered from those sensors and the ideas for how you'd like the sensor data to affect the driving. Greg McKaskle |
My assumption was that a gyro and PID loops would make it the difference between smooth and "smooth". I could be wrong?
I understand that a good mechanical design is needed. What I want to assume is that mechanical is mostly perfect and we want sensors to correct any errors. Right now, we do not have sensors mounted. However, we are getting a NAV6 IMU sensor to mount to give us that extra "oomph" (we haven't had good experiences with those AndyMark/KOP gyros). Thanks! Last edited by Joseph DeRoest : 04-01-2015 at 19:23. |
We'd like to help you, but we need to understand what you are trying to accomplish before we can give suggestions how to do it. Quote:
Or, are you just seeking suggestions how encoders and IMUs can be used with a drivetrain? |
