Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
Unread 01-04-2015, 07:15 PM
Manusha4Lyfe Manusha4Lyfe is offline
FRC #5124
Manusha4Lyfe is an unknown quantity at this point
Unhappy RobotBuilder Not Opening Through Eclipse
Our team just downloaded all of the needed components for using Java through Eclipse for the RoboRIO (eclipse, update Java8, WPIlib plugins, UpdateSuite). RobotBuilder opens independently, but not through Eclipse. When it's open independently, we can't open the project in Eclipse. Any suggestions?
Unread 01-05-2015, 01:19 PM
cdewane cdewane is offline
FRC #3381 (Droid Rage)
Rookie Year: 2013
cdewane is an unknown quantity at this point
Re: RobotBuilder Not Opening Through Eclipse
I'm at work and don't have my laptop here for specifics, but here is what I did.
1. Open eclipse for the first time and create a worspace. You can use the default or enter your own path. Either way, make note of the path.
2. Open Robotbuilder by double clicking on the jar file.
3. Create a new robot in RB. On the main page put the workspace path into the Eclipse Workspace field.
4. Save and export in RB.
5. Go back to Eclipse. Click on File, Import. In the Import dialog, click the triangle next to General. Then click Existing Projects...
6. After exporting the robot there will now be a folder under the workspace path matching the robot name, select that.
You should now have the robot project in the project explorer.
Check this link for how to have Eclipse automatically refresh code files after they have been modified by RB. You still may have to manually refresh the Eclipse project after adding new source code files from RB. If you add or rename subsystems, commands, etc and you don't see it in Eclipse after exporting from RB, right click the project name and select refresh.
https://wpilib.screenstepslive.com/s...-robot-project
Unread 01-05-2015, 02:22 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Do any of the other items in the wpilib menu start? We have one computer that won't start any of them, but they all run manually and RobotBuilder is able to create eclipse projects and we are able to import them into eclipse. Launching from eclipse works on the other computer's we've tried.
Make sure you're starting the 2015 version manually, rather then the 2014 version. The 2015 version location is documented here: http://wpilib.screenstepslive.com/s/...g-robotbuilder
Originally Posted by cdewane View Post
FYI, that link is actually to the 2014 instructions. It won't cause a problem if you're only on that page, but if you move around you'll get old instructions. Here is the 2015 link: https://wpilib.screenstepslive.com/s...-robot-project
Unread 01-06-2015, 11:31 PM
FRC #5124
Thanks! I tried your suggestions and it works. None of the launchable items from wpilib launch from eclipse, but importing into eclipse works and it updates automatically once you import, and i can still run the wpilib stuff through the jar files. Thanks for the help!
Unread 01-25-2015, 05:56 PM
MitchTolson MitchTolson is offline
FRC #3393
MitchTolson is an unknown quantity at this point
I had the same problem where robot builder and the other tools were not launching from Eclipse.
from a cmd prompt: java - version, returned a mismatch. Where, I had version 8, but the registry was expecting version 7.
To solve, I uninstalled all versions of Java, restarted, then reinstalled the latest version of java.
Unread 01-04-2016, 05:29 PM
Cdog Cdog is offline
FRC #3853
Cdog is an unknown quantity at this point
Workspace not worspace
