Code without Eclipse!
Do you, like me, have an irrational aversion to IDEs? Do you just want to stick to your gedit, vi, or nano? Well, never fear, I have come to the rescue! After a few hours of digging through the Eclipse plugins and the FRC toolchain, I have created something to replace Eclipse: a makefile. Simply head over to https://github.com/brpylko/FRCMakeProject, download the repository as a zip archive, and you're ready to start coding. I've tried this on Ubuntu, but it should work on all Linux distros. I have no idea if it will work on Mac OS, but I'm sure it won't work on Windows. If you have any problems/suggestions, open an issue on GitHub.
Re: Code without Eclipse!
arm-frc-linux-gnueabi-g++ -I${HOME}/wpilib/cpp/current/include file.cpp -o file.o and link with arm-frc-linux-gnueabi-g++ -L${HOME}/wpilib/cpp/current/lib -lwpi files.o -o FRCUserProgram There is even a CMake toolchain file distributed with the ubuntu toolchains in the package frcmake (nothing prevents it from being distributed with windows and mac but that would require re-building the toolchains, while ubuntu it was a single package addition): https://bitbucket.org/byteit101/tool...ake?at=default Note it doesn't have a deploy target but I'll gladly accept pull requests. |
I don't really have any experience with CMake, that's why I wrote a makefile. If I have time I'll learn and submit a pull request with deploy capabilities.
So does the FRC toolchain just use the armel gcc with links to NI libraries? I haven't delved deep into gcc before but that's what it looked like when I was browsing your repository. |
So the roboRIO supports C++14? I'll have to update my makefile accordingly if so. |
That's awesome! So for a novice person to the in-depths of the roboRIO, how would you "deploy" it? Just ssh into it and replace the image with the one generated?
You might also be able to just use ant to call that script, as I'm not sure how make does with ssh and scp. |
Yeah, that's what I meant
.I also just remembered: what does the "-t" option for the robot kill script actually do? I know it says something like start the program as a text program, but I don't know what that means. |
