Go to Post I had a fight with my robot once during competition. I felt bad about it and apologized. - Tommy F. [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
  #16   Spotlight this post!
Unread 05-01-2015, 13:52
Scott Kozutsky's Avatar
Scott Kozutsky Scott Kozutsky is offline
FRC #0865
Rookie Year: 2010
Scott Kozutsky will become famous soon enough
Re: Picking Up Upside-down Totes?
It should be reasonably easy to flip totes. While this (http://youtu.be/qfu9l_OF_gw?t=2m4s) is definitely not an FRC link, I feel like it effectively shows a possible (albeit massively overpowered) system for flipping totes. If you compacted it you could probably just bolt it to the back of your bot. It's not like it requires anywhere as much force to flip a tote.
I don't think it's reasonable to stack totes on top of an upside down tote that's being held with friction. Then again, your robot design and experiences may vary from ours.
2010-2012 FRC 865 Warp7 Student, Mechanical
2013 FRC 1310 RUNNYMEDE ROBOTICS Student, Mechanical, Design
2014 FRC 865 Warp7 Student, Mechanical, Design
2015 FRC 865 Warp7 Alumni, Mechanical Mentor
  #17   Spotlight this post!
Unread 05-01-2015, 14:33
aasrobotics's Avatar
aasrobotics aasrobotics is offline
Battery Chargers 4676
FRC #4676 (The Battery Chargers)
Rookie Year: 2013
aasrobotics is an unknown quantity at this point
Wait, couldn't you make basically a flapjack flipper? Yknow, to flip over the disoriented totes? Just a thought, not really sure HOW to accomplish this, but just wondering.
  #18   Spotlight this post!
Unread 05-01-2015, 14:34
Batterink Batterink is offline
FRC #4519
Batterink is an unknown quantity at this point
My fear for building a device that flips totes is flipping them onto, or over, the step.
  #19   Spotlight this post!
Unread 05-01-2015, 15:05
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Originally Posted by nxtmonkeys View Post
You could just have a little arm with a spatula-like thingie on the end of it.
Here; I made a picture:
(yes, I am a bit bored. How did you know?)
Your pic is for flipping over an upside down tote. My question was for a tote laying on its side.
Also, your design assumes enough friction to keep the tote from sliding, and that there is room behind the tote.
  #20   Spotlight this post!
Unread 05-01-2015, 22:15
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Originally Posted by SamCyanide View Post
What I would do is have two pads (possibly rubber or something else that can grip plastic well) that are built off of arms with motors on them. This way, you can grab the tote and flip it right side up by using the motors. You could even do this in testing and have it automatically rotate the motors (and as a result the container) only a certain number of degrees.
We prototyped this, but we decided passive pads on bearings would be simpler. (Our new designs being considered at the moment don't involve this system yet, since we are still speculating if flipping is necessary.)
If you pick up a tote off the ground with the pads within the area that is the bottom half of the tote, whether it is right side up or upside down, it inverts since the point of contact is off center and near bottom, and the object wants to find a point of rest with minimal potential energy. That point of rest is met when the point of contact is now above the middle of the tote. i.e. When the tote flips when held at the bottom, it rotates down so then it is being held at the top half. So this works for flipping totes that are upside down, right side up, and it can also be possible to use it for the containers. The only thing that needs to be powered is the pinching and lifting so the tote or container can get off the ground to swing to its natural position due to gravity and the off center contact points. I recommend playing with that idea.
  #21   Spotlight this post!
Unread 06-01-2015, 00:31
221Sarahborg's Avatar
221Sarahborg 221Sarahborg is offline
Alumna Mentor
AKA: Sarah S.
FRC #1810 (Jaguar Robotics)
Rookie Year: 2012
221Sarahborg is an unknown quantity at this point
The only strategy I found with trying to deal with the upside down totes was to get to the extra containers on the step if your reach was short range, when the human players have plenty more totes in the Alliance Station available to the robots.
KU SADP
1810 - Jaguar Robotics
Alumna Mentor for Electrical & Driving
Team Website & Twitter
  #22   Spotlight this post!
Unread 06-01-2015, 07:10
Kayla_Wallet's Avatar
Kayla_Wallet Kayla_Wallet is offline
Co-Captain
FRC #5050 (Cow Town Robotics)
Rookie Year: 2014
Kayla_Wallet is an unknown quantity at this point
My team decided to go with a pincer style grabbing mechanism, and we decided to use a material similar to the grippy stuff on tennid rackets with a bearing on the "hand" part so no matter which way grabbed, it will turn right side up because of how the weight is distributed.
  #23   Spotlight this post!
Unread 06-01-2015, 08:25
diddoarch710's Avatar
diddoarch710 diddoarch710 is offline
FRC #4009 (Denfeld Nation Automation)
Team Role: Marketing
Rookie Year: 2014
diddoarch710 is an unknown quantity at this point
Originally Posted by Michael Hill View Post
Do you really need to? There's enough that are right side up. Perhaps it would be easier to just move the upside down ones out of the way.
Yeah, that's what my team was saying. One of the people on my team did the math and he said the max points you could make not including time is 408, and those upside totes only count for like 20 or something like that, so it probably won't be significant when you have more than enough right side up totes. They may become more relevant in Nationals, and by then you'd have more time to make changes so that you could deal with the upside down bins. I'd say they aren't very relevant unless you're with a team that can quickly and efficiently stack all totes and bins so that you'd actually need the upside down ones. 10 out of the 64 totes are upside down, I don't think they'll really need to come into play till nationals, or if you really need points on your average (since you don't win individual matches till eliminations) or wanna go try hard mode.
  #24   Spotlight this post!
Unread 19-01-2015, 22:30
Deucalion's Avatar
Deucalion Deucalion is offline
Math Addict
AKA: Gabe
FRC #4531 (STEMpunk)
Team Role: Leadership
Rookie Year: 2013
Deucalion has a spectacular aura aboutDeucalion has a spectacular aura about
Thumbs up Re: Picking Up Upside-down Totes?
Ah! The gravity flip certainly is a fine idea, I must say. The only trick here is implementing it on the fly.
"We Don't Just Build Robots, We Build People." -STEMpunk 4531
