Go to Post Welcome to FIRST! It's in your blood now... - AmyPrib [more]
Unread 05-01-2015, 10:54
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Transporting very large robots?
So I have been trying to figure out how to transport robots that people might design to maximum height limit? Top of trailer can be restricting...not to mention a shipping crate to champs...unless there is something new about shipping that I haven't read? I can see this being a problem, laying the robot down can take up a lot of room and possible damage to robot. Disassembling it could also take a lot of teams tons of time if they don't plan to be modular. What are your thoughts?
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 05-01-2015, 10:58
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Re: Transporting very large robots?
Well, for transportation, the robot has to be able to be easily transformed into transportation configuration, which has to fit in a 28x42x78, which isn't all too large.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 05-01-2015, 11:00
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
78" is very large when you're looking at standard doors and the fact that there's probably a cart of some height under it.
Unread 05-01-2015, 11:02
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
I'm 5' 11" and still hit my head on our trailor....
Unread 05-01-2015, 11:08
AKA: Michael Shires
FRC #0384 (Sparky)
In retrospect, that is actually quite high...still though, you could just set it down so it's only 28 inches high. six and a half feet is still quite long...I see your dilemma. Perhaps teams with limited transportation abilities should design around those? maybe tall robots should also try to fold down?
Unread 05-01-2015, 11:09
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Even if I get my old bread truck running by competition season, it's only 73" inside height, and the rear doors are a bit less. The rear doors on my Suburban are less than 43" high.
Unread 05-01-2015, 13:28
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Does anyone see a problem here for shipping to champs?!?!
Unread 05-01-2015, 13:36
vhcook's Avatar
Reader of Things
AKA: Victoria
Yes! The max height is well over what I recall as the max height of a crate. I can't find the alleged "'Shipping Crate Construction' document posted with the FRC Administrative Manual", but I seem to remember the limit as something like 48" including the boards that go under to allow the forklift access.
Unread 05-01-2015, 13:42
RallyJeff's Avatar
RallyJeff RallyJeff is offline
FRC Referee & FLL Many-Hats-Wearer
AKA: Jeff Hagan
Rookie Year: 1995
RallyJeff has a spectacular aura aboutRallyJeff has a spectacular aura aboutRallyJeff has a spectacular aura about
The minivan I used to have (Dodge Caravan, not the "Grand" Caravan) had a cargo area that was almost exactly 6.5 feet long with the seats removed. However, due to the shape of the rear door, it was shorter than that near the roof.
A Grand Caravan will hold a 4 foot x 8 foot sheet of plywood. I can't recall the exact height, but from what I recall, the back opening is not quite as tall as it is wide... about 3 feet, maybe?
If you're planning a large robot, it might be a good idea to measure the vehicles your team has available... or look around your community for a sponsor who could supply a trailer or cube van.
Unread 05-01-2015, 13:53
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The FedEx max crate size is 48x48x70. So your ship dimensions to worlds will need to be somewhat smaller than that.
If you don't know what you should hook up then you should read a data sheet
Unread 05-01-2015, 15:00
Doug Frisk's Avatar
Doug Frisk Doug Frisk is online now
Keeping Score
AKA: Doug Frisk
Rookie Year: 2011
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
A standard door height is 80 inches but there may be a threshold at the bottom or closer arm at the top impinging on that. At the Northern Lights regional in Duluth, there are two doors that robots will need to traverse between the pits and the field.
I'm pretty sure one of them is more than 80 inches high, but I'm not sure about the other. Could be interesting times for queuing if some of the teams have to pull their robots off a cart to fit through the door.
Unread 05-01-2015, 18:38
mrmummert's Avatar
mrmummert mrmummert is offline
AKA: hank
FRC #1610 (bot)
mrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to beholdmrmummert is a splendid one to behold
Send a message via Yahoo to mrmummert
Either First is expecting us to use the shipping crate size we used last year (48x48x70) or they haven't posted new crate rules and dimensions for this year. If we have to use the 2014 dimensions then either you have to build your robot to fit in that size or be able to take part of it apart to fit that. I hope they clarify this soon as this is something teams need to know while designing.
winner vcu 2006,winner vcu 2013,2014,2015
Unread 05-01-2015, 19:52
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
I've read that similar issues came up in 2007 (Rack n Roll) where you could have a 72" robot, but the crate was still the same size and somewhat shorter than your bot could be. Basically, you just had to deal with it (though crates were for every event, not just CMP).
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 05-01-2015, 22:13
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
That is a FedEx size, not a arbitrary First thing. I don't expect it to change.
  #15   Spotlight this post!
Unread 06-01-2015, 09:37
RallyJeff's Avatar
AKA: Jeff Hagan
Rookie Year: 1995
FYI for anyone going to the Windsor Essex Great Lakes Regional but don't know the layout: our load-in door is a large roll-up door that you could literally drive a truck through. The pits and arena are part of one large space that we divide up for the event, so the limiting factor for height while carting around a robot will be the rod-and-drape dividing the pits from the arena.
