Go to Post I hope we as a team can learn the value of doing less but doing it incredibly well. - Rob Stehlik [more]
Unread 05-01-2015, 14:09
motherrussia motherrussia is offline
FRC #3570
motherrussia is an unknown quantity at this point
Exclamation Problems with labview Install
I have recently installed Labview from the disk that is entitled NI software for 2015 that came in our kit. When I opened the program I was met with this[http://imgur.com/dPZG3ij] screen. I am very perplexed as this is very different from the window that the QuickStart power point shows. Does anybody know a solution to this?
Unread 05-01-2015, 14:17
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Problems with labview Install
Can you post a link to the QuickStart powerpoint you are referencing?
The most likely cause is that you did not install the 2015 FRC Update Suite. See http://wpilib.screenstepslive.com/s/4485/m/13503
Unread 06-01-2015, 12:51
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Rookie Year: 2011
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
I concur, this is indeed an important update to install as it contains all the libraries, example code, and project framework. It is a pretty quick update.
