Go to Post Cash is always better, remember that when fund raising. - LordDumpling [more]
Unread 05-01-2015, 16:20
jreneew2's Avatar
jreneew2 jreneew2 is online now
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
Rookie Year: 2013
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Eclipse x64 bit C++ WPIlib plugin not showing up in Run As... menu
Hello again! Our team is trying to deploy code to the roboRIO using 64 bit eclipse and we have run into a problem: I have installed 64 bit java, 64 bit eclipse, the C++ toolchain, the FRC Update Suite and the WPI lib plugins for C++ and Java. It should work but doesn't. The problem is that when you right click on the project and go to Run As... it only shows the Java WPIlib program.
Am I supposed to use the C++ Application? Or is there a WPIlib C++ Run config? I also can successfully build the program, I just can't deploy.
Thanks for the help,
Drew
Unread 05-01-2015, 20:02
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Eclipse x64 bit C++ WPIlib plugin not showing up in Run As... menu
There is supposed to be a WPILib C++ Deploy entry, see http://wpilib.screenstepslive.com/s/...to-the-roborio
I saw one computer that had this issue at a Robot Quick Build session this weekend. I posted about it on the FIRST forums here: http://forums.usfirst.org/showthread...ws-Java-Deploy
Since you have access to a computer that shows the issue, maybe you could post there and FIRST could help troubleshoot.
Unread 05-01-2015, 22:11
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
There's a bug in something with the plugins where once you do something with the Java perspective, eclipse looses track of the type of project and won't offer C++ build and download. If you restart eclipse, in that case, the build options will show up again for C++ projects.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 06-01-2015, 16:55
jreneew2's Avatar
AKA: Drew Williams
Rookie Year: 2013
Thanks! I will try that as soon as I get the chance! I will report back with results!
Unread 19-01-2015, 14:43
Rookie Year: 1997
Did you get it working?
Unread 19-01-2015, 15:11
jreneew2's Avatar
AKA: Drew Williams
Rookie Year: 2013
Yeah! I tried restarting eclipse and it worked. Sorry for the late response.
Unread 21-01-2015, 20:59
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
I have an issue where
Run As --> "WPILib C++ Deploy"
is not an option.
I have re-installed Eclipse, the Plug-Ins, etc. several times to no avail. Installing the Java Plug-ins instantly gives me the "WPILib Java Deploy" option, but no amount of restarting or re-installing or update attempts will show the "WPILib C++ Deploy" option.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 22-01-2015, 23:23
walterev walterev is offline
FRC #1758
walterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to allwalterev is a name known to all
Had the same problem with a 32 bit system but after a remove/install of Eclipse the option was available. I had been working with sfx before the issue occurred.
Walter
Unread 27-01-2015, 12:48
RobHammann RobHammann is offline
FRC #5143
RobHammann is an unknown quantity at this point
I am having the same problem
In the run as menu i only have options to deploy java, i have rebooted and restarted and reinstalled but i haven't seen the option to deploy as c++ available once
I am using the 32 bit version
Unread 27-01-2015, 14:05
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
What if you drill down to "Run As..." by right clicking the project folder? That's where it shows up for me.
I only get the C++ deploy when doing this. The Run As... via the Run menu never seems to provide the same option. 64-bit machine.
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 27-01-2015, 14:11
FRC #5143
That is what I was referring to, right clicking on the project folder and going into Run As only has options for local C++, WPI Java deploy, and WPI Java sim
Unread 27-01-2015, 16:48
Nyxyxylyth Nyxyxylyth is offline
AKA: Neal Manson
FRC #1481 (The Riveters)
Rookie Year: 2013
Nyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really niceNyxyxylyth is just really nice
I have to run Eclipse as an administrator for Deploy to show up in the Run As menu.
Unread 28-01-2015, 18:37
FRC #5143
Right clicking on build and running it as ant is working for me, I hope that won't cause any future problems
Unread 05-03-2016, 19:19
johnny_Bet johnny_Bet is offline
Dark Lord of Code
AKA: Johnny Bettencourt
FRC #4643 (Thunderbird Robotics)
Rookie Year: 2015
johnny_Bet is infamous around these parts
Thumbs up Re: Eclipse x64 bit C++ WPIlib plugin not showing up in Run As... menu
We were having this problem as well and were trying for hours to fix it, we finally uninstalled the toolchain, went to window > prospective > reset prospective, than we reinstalled the toolchain.
  #15   Spotlight this post!
Unread 07-03-2016, 20:17
cd94035 cd94035 is offline
FRC #1868 (Space Cookies)
Rookie Year: 2105
cd94035 is an unknown quantity at this point
I faced the same problem on my Mac but was able to fix it by just resetting the Perspective in eclipse: Window -> Perspective > Reset Perspective.
