Go to Post “FIRST is your experience and you cannot let anyone else hinder what you can achieve.” - fuzzwaz [more]
Unread 05-01-2015, 17:49
Herbie_3633 Herbie_3633 is offline
FRC #3633
Herbie_3633 is infamous around these partsHerbie_3633 is infamous around these parts
Error when deploying code on to robot. build.xml:66 (C++, Eclipse)
Code:
C:\Users\My Dell\wpilib\cpp\current\ant\build.xml:66: com.jcraft.jsch.JSchException: Could not send 'C:\Users\My Dell\workspace\Robot\Debug\FRCUserProgram' to '/home/lvuser' - 4: java.io.FileNotFoundException: C:\Users\My Dell\workspace\Robot\Debug\FRCUserProgram (The system cannot find the file specified)
The laptop is 64 bit windows 7. I found some other occurrences of the error on wpilib.screenstepslive.com/ but no way to fix it. Does anyone know how to fix it and/or avoid it in the furure?
Unread 05-01-2015, 18:43
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Error when deploying code on to robot. build.xml:66 (C++, Eclipse)
This likely means your project didn't build. What does the Build Console show when you build the project? Do you have an FRCUserProgram in the debug folder inside your project?
Unread 05-01-2015, 22:29
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
The other likely source of that error (line 66 of build.xml) is the script trying to copy your program onto the roboRIO. I usually see that when there is no connection to the robot. Can you make sure by browsing to "roborio-<yourteamnumber>.local and see if that works to verify connectivity and that the name of the roboRIO can be resolved? That usually fixes it for me.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 10-01-2015, 13:59
nollchr nollchr is offline
Rookie Year: 2014
nollchr is an unknown quantity at this point
We experienced a similar error and it turned out to be the team number not filled in under Preferences->WPILib
