Our team wants to create a slide chassis this year, and were considering doing this by switching the 4" KOP wheels provided with 6" omni wheels, and then adding two perpendicular omni wheels in the center, at each end of the frame.
Our question was whether it was possible to connect the omni wheels to the current belt drive system, what interfaces/hubs we would need, and whether or not the belt would interfere with the wheel itself? Similar to this: https://www.youtube.com/watch?v=JqJK0E9Jpmk |
Re: Omni Wheels with KOP Andy Mark Chassis
If you are using these, the included pulleys will interface. You will just need to make custom spacers since they are thinner than the HiGrips. The belts will not interfere with the wheel due to the pulley flange and the taper of the wheel. For 6 inch wheels you will most likely use the holes specified for the square oriented chassis. The AM14U2 User Guide says to use 151 tooth (am-2706) belts for that.
![]() Last edited by Mike Marandola : 01-05-2015 at 11:22 PM. |
What do you mean by height clearance? So it doesn't hit the flanges?
Yes, That is exactly what I mean, Whether the thicker Vex Omni's will fit between the flanges
They will be cutting it close. The distance between flanges is 1.75". The center wheel is what would cause an issue since there is not much room to move side to side. I would advise you to assemble it in CAD or contact AM.
#10
This is the video that was removed. It is an AM14U2 with an 80/20 rail to support their slide gearbox.
#13
Does anybody know how can we use 4" andymark omni wheels in KoP chassis? Can we just put dualie 4" Omni wheels instead of hi grip wheels or do we need to buy or make special hubs or spacers?
#14
Are you sure about that? The DuraOmni wheels are significantly wider than the included HiGrips. New spacers will have to be made at the very least.
