Go to Post It can't be too bad... it's Canada! :) - Brandon Martus [more]
Unread 05-01-2015, 22:58
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
Rookie Year: 2013
xXhunter47Xx will become famous soon enough
Why do the pneumatics not work?
https://github.com/Patribots4738/BattleOfTheBorder
Here's our code on git.
Currently the solenoid fires once and then the code crashes, and the compressor does not start.
The pressure switch is wired correctly, NC connected to DIO signal and C connected to DIO (-). The compressor is wired to a spike, and the spike is connected to a RELAY port.
In the code you can see that they're both correctly inputted (if the right code is uploaded of course).
We're kind of stumped.
College sux yo
Unread 05-01-2015, 23:11
ejb1123 ejb1123 is offline
AKA: E.J. Bevenour
FRC #5404 (Gearaffes)
Team Role: Leadership
ejb1123 is an unknown quantity at this point
If you don't define pcmID it defaults to 0.
Unread 05-01-2015, 23:16
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
Rookie Year: 2013
x86_4819 is on a distinguished road
Re: Why do the pneumatics not work?
Why do you have a "while (true)" loop inside your TeleopPeriodic? TeleopPeriodIc will automatically get called every 20ms, so there is no need for you to have your own loop inside of it. That is probably the source of your problem, as you aren't letting anything else run while your while loop is iterating infinitely.
My Github Repositories
Unread 05-01-2015, 23:23
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
Rookie Year: 2012
tStano will become famous soon enough
Is this on a roboRIO or a cRIO?
if its a roboRIO, there are multiple issues with the legality and likely the functionality of this. You will need a pneumatics control module in your system, on a CAN network with the roboRIO, Power distribution panel, etc.
If its a cRIO, the people above me probably are on the right track.
Unread 05-01-2015, 23:28
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
Rookie Year: 2012
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
With the 2015 wiring you don't need to connect the compressor to a spike, just wire it into the PCM (Pneumatic control module) along with the pressure sensor.
Unread 06-01-2015, 12:34
Lord of Lazy
Rookie Year: 2013
Should have specified, it's a cRIO. The issue was a crimped PWM. I'll bring up the while loop issue with the rest of programming though. Thanks everyone!
College sux yo
