Go to Post A dedicated team is a happy team. - sgreco [more]
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Unread 11-01-2015, 21:39
DavisC DavisC is offline
FRC #0539 (Titans)
Rookie Year: 2010
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Angry Re: LIDAR Sensor has arrived!
Thanks, so I just use kMXP instead of kOnBoard and connect to the expansion port bottom left 2 pins for sda and scl?
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 11-01-2015, 21:45
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Correct. I still had my sensor power pins plugged into the I2C power and ground ports, which seem to work (for what it's worth).
Also, if you execute myLidar.start(); in your init area or constructor, you can access myLidar.getDistance() in both autonomous and teleOp methods and allow it to run its own thread, which will help avoid bogging down the rest of your code (because the update() method includes delay timers up to ~10ms to write and read).
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 12-01-2015, 20:45
WDB WDB is offline
FRC #2363
WDB is an unknown quantity at this point
We tried the I2C port too and failed. Moved over to the MXP and still getting zeroes.
Using lidar.start() in the teleopInit and calling lidar.getDistance() in teleopPeriodic which is returning zero. Am I missing anything?
Thanks!
Unread 02-02-2015, 11:23
co1inw co1inw is offline
Student
AKA: Colin Willoughby
FRC #1768 (Nashoba Robotics)
Rookie Year: 2013
co1inw is an unknown quantity at this point
Originally Posted by tech2077 View Post
In case anyone is interested, I wrote up a java class for this, you can use the start/stop functions to use the built in updater Timer, or use the update function to only poll distance when needed.
LIDAR.java
Please correct me if I'm wrong, but there appears to be a bug in this file. You are calling updater.scheduleAtFixedRate(), which would be fine if you didn't already have a while() loop inside your TimerTask. Since you have a while loop, the run() function will never exit, so essentially your timer is useless and is acting like just a Thread object to run this function in the background indefinitely. The 'period' argument isn't being used, so the sensor will be polled every 10ms.
Also, since it came into the discussion, our team is using Java and we have been able to successfully use our RoboRio I2C port for a MaxBotix ultrasonic sensor, but not for the LIDAR sensor. Trying to use the LIDAR gives us write and read errors.
Unread 02-02-2015, 18:48
Pi Fighter's Avatar
Pi Fighter Pi Fighter is offline
Insert Monty Python Reference Here
AKA: Trevor
FRC #1718 (Fighting Pi)
Pi Fighter has a spectacular aura aboutPi Fighter has a spectacular aura about
Hello all, a while ago our team posted that we were able to successfully collect data from the Lidar sensor using LabVIEW. Today I'm posting the code we're using to collect the data, as well as pictures of the placement of these VI's in the robot project. Feel free to use them as needed.
Name:	1718 Lidar Code (Begin).png
ID:	18104  Click image for larger version
Name:	1718 Lidar Code (Periodic Tasks).png
Unread 08-01-2015, 00:40
PaulDavis1968's Avatar
PaulDavis1968 PaulDavis1968 is offline
Embedded Software/Systems Engineer
AKA: Master of Complexity
FRC #2053 (TigerTronics)
Rookie Year: 2012
PaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nicePaulDavis1968 is just really nice
Ordered! I have been drooling over this for 6 months. And we might have a use for it. I was going to buy it for my self regardless. If it works out I will get one for the team so we have two.
Unread 08-01-2015, 06:21
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Based on the datasheet it seems this wouldn't work on polycarbonate, since it transmittance is just as high at 905nm as it is in the visible spectrum, and the laser would mostly go right through. I really don't know much about LIDAR systems, so does anyone else with more experience know if this would be the case?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 08-01-2015, 09:46
Rookie Year: 2012
I asked this question on their forum.
https://groups.google.com/forum/#!forum/pulsedlight3d
Unread 08-01-2015, 10:27
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Polycarbonate doesn't have 100% transmittance for near IR, but it's still very high. You will get a small amplitude return from polycarb, which will be higher if there are scratches or dirt on the surface, or if you are getting specular returns from other light sources. You can configure the LIDAR-Lite to present either the strongest, first, or last return to you, and I'd expect whatever is behind the panel to be the strongest return the vast majority of the time (but not always).
Experientially, LIDAR sucks for detecting transparent objects and requires lots of signal processing and integration of multiple scans over time to have any chance of accurately detecting a transparent object.
Unread 08-01-2015, 11:01
seg9585's Avatar
AKA: Eric
FYI, I have detected distance to transparent windows with moderate levels of success. I'd assume polycarbonate behaves similarly, but would have to do more testing. We are programming up the LIDAR against the roboRio tonight so I'll try it out.
My FIRST legacy:
Unread 20-01-2015, 11:09
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Man I wanted one of these and I don't even have a reason...
Any cool uses for them I have a couple ideas but none of them are viable this year cause auto too short...
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 23-01-2015, 12:09
Rookie Year: 2012
I wanted one of these period. I don't care if we use it.
Unread 07-02-2015, 13:11
muvicado muvicado is offline
FRC #0135
muvicado is an unknown quantity at this point
Just wanted to share that a new LIDAR (laser radar/rangefinder) is out on the market from "PulsedLight3D" for $90 -- Class I laser so it's FIRST legal. Just arrived today in the mail, and I hooked it up to my Arduino:
Did some initial testing via I2C, seems to be very accurate between ~20cm and 650cm (as far as I could test it tonight without finding a larger room), 0.5 deg beam width
Here's a snapshot of my Serial output with distance in cm (~100 Hz samples averaged and output at 5 Hz), sitting on my desk facing up to the ceiling.
http://pulsedlight3d.com/
We're going to have fun with this!
Do you know if more than one LIDAR-Lite can be connected via CAN through the MXP's can bus?
The LIDAR-Lite appears to have a fixed slave address - 0xC4.
LIDAR-Lite Spec
Why would they not make it configurable? Seems like that would prevent one from being able to use multiple LIDAR-Lites on the same I2C bus.
Maybe I'm missing something. The LIDAR's slave address must be configurable somehow.
Unread 07-02-2015, 14:59
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The pre-release descriptions all talk vaguely about being able to control multiple devices on the I2C bus, but none of the available documentation I've been able to find mentions anything about configuring the slave address.
  #15   Spotlight this post!
Unread 07-02-2015, 15:41
FRC #0135
LIDAR-Lite Spec
Okay, I discovered the slave address can't be changed on the current version of LIDAR_Lite. From PulsedLight's forum, I learned a work-around for this. Using a DIO pin for each LIDAR, connect pin 2 of connector J1 on the LIDAR to a dedicated DIO pin on the RIO, using this as a "device select" line. Just before and just after the Write/Read sequence to each LIDAR, set teh LIDAR's device select high and low, respectively. We will try this out, using a C++ application.
