Go to Post I'm thinking they subscribe to the thought that "the best offense is a good defense". They are from New England, after all. - Travis Hoffman [more]
Unread 06-01-2015, 15:03
patel9825's Avatar
patel9825 patel9825 is offline
Senior leader
AKA: Purvangi Patel
FRC #4939 (AllSpark9)
Team Role: Mechanical
Rookie Year: 2014
patel9825 is an unknown quantity at this point
Motor suggestion pls!!!!!!
Can you also suggest a motor that can lift 60-70 lbs without burning out???
Thank You,
Team 4939,AllSpark9
Unread 06-01-2015, 15:06
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: Motor suggestion pls!!!!!!
Any motor. Assuming no friction and the proper gear ratio.
How fast and how far does it have to lift this weight? You need those numbers, and then you need to guess an efficiency of your mechanical system.
Unread 06-01-2015, 15:15
Ken Joe 5625's Avatar
Ken Joe 5625 Ken Joe 5625 is offline
Hawaiian
FRC #5625 (St. Anthony Trojans)
Team Role: Tactician
Rookie Year: 2015
Ken Joe 5625 is an unknown quantity at this point
Thank You,
Team 4939,AllSpark9
I'm sure any moped motor would work just fine.
however I'm sure a K series motor out of a student or mentors Honda would also work.
Unread 06-01-2015, 15:31
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
1 CIM motor going through a 12:1 versa planetary driving a 2 inch pitch diameter(1 inch R) sprocket.
Can lift a 62.5 pound(1000 ounce) load at 335RPM or 3 feet per second.
At 35 amps and 60% out of 64.7% max motor efficency.
Torque at motor 83.3 oz-in. At sprocket with no accounting for losses in 1000 oz-in at a lever arm of 1 inch.
TLR CIM motor handles it like a boss! 1 Mini CIM should be able to lift the load, but slower. 2 Mini CIMs should take it like a champ.
Unread 06-01-2015, 15:40
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
...you are aware that there are restrictions on what motors teams are allowed to use in FIRST, correct?
Originally Posted by R18
R18 The only motors and actuators permitted on 2015 FRC ROBOTS include the following:
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 06-01-2015, 15:41
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
I think he was joking...
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 06-01-2015, 15:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Please try to be actually helpful or just don't post.
For to the original question:
As Nemo said, it depends on the motor and the gear ratio. If you gear down a motor enough, it can lift anything, as long as there's no friction in the gears. Practically speaking, a 1000:1 over all gear ratio is the biggest you'll probably ever see in FRC. And that would be sloooow.
Firstly, Ken Stafford has a good (but long) video on how to pick a motor and gearbox.
Secondly, here's a link to the 2015 Motor Performance Data that you can use with the info from Ken's video to pick a motor and gear ratio.
If you want the short version, one of the fundamental equations is:
Power = Force * Speed or,
Speed = Power / Force
You want something that will lift 70 lbs of force. A CIM motor's max power is 330 Watts which Online Conversion tells me is 244 foot-pounds-force/second.
So, 244 / 70 = 3.5ish. A CIM motor geared for max power can lift your load at 3.5 feet per second, assuming no friction or losses. It's usually better to assume losses and to not aim for exactly maximum power, so a safe bet is to cut that in half and say a CIM motor can lift 70 lbs at 1.75 feet per second.
The_ShamWOW88's Avatar
The_ShamWOW88 The_ShamWOW88 is offline
Senior Mentor/Coach
FRC #0157 (Aztechs)
Team Role: Coach
The_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to beholdThe_ShamWOW88 is a splendid one to behold
I sense sarcasm...
"The best way to predict the future is design it"
"Striving for excellence through inspiration"
