Go to Post oooo can i get bear hugged at monty madness...please big mike, please - Rohith Surampudi [more]
Unread 06-01-2015, 15:08
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
Team Role: Leadership
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
#25 Chain Drive System Questions
Our team is looking to build a drive system using #25 chain to drive the wheels. We have some experience using #35 chain in drive systems but in an effort to keep the drive base as light as possible and since there is no defense this year, we figured #25 chain would be adequate.
Having never used #25 chain for drive systems, I'm trying to figure out a few things for the design:
  1. How do you calculate spacing between sprockets to minimize the need tensioners? Is there also a way to take idlers into account?
  2. We would like to run 3 wheels from a single chain to minimize the width of the drive base, is there a minimum chain contact area on the sprocket that is needed to avoid slipping?
  3. We've used a chain break tool to splice #25 chain and avoid master links in the past on various mechanisms, is it still ok to do that with a drive system?
  4. Is there anything we should watch out for that is different when using #25 chain on drive systems compared to using #35 chain (or in general for that matter)?
Unread 06-01-2015, 15:28
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
Re: #25 Chain Drive System Questions
1) There are calculators available on-line for simple chain configurations. i.e. between two sprockets. If those sprockets are the same size, you only need to space the axels in 1/4" increments for #25 chain. If you use a half-link you could work on 1/8" centers. However, to drive 3 wheels from a single chain is significantly more complicated and may require the use of CAD for your specific configuration.
2) Obviously, the more wrap you use on a sprocket, the less likely it is the chain will be able to jump. The general rule of thumb I use is 120 degrees of wrap, but geometry does not always allow that. With reduce load on the chain you can use less wrap on each sprocket, but I caution against going with less than 90 degrees of chain wrap.
3) I've always used master links. When properly installed I have never had an issue with them. Simply need to make sure the retaining clip is properly engages with the grooves on the posts.
4) #25 chain can no handle the loads that a #35 chain can. You need to make sure you do not over load the chain and cause it to yield/stretch/fail. As with any chain proper alignment of sprockets is critical for keeping chains on sprockets. My experience is that #25 tends to 'relax' or stretch more than #35 chain after some use. I attribute this to the greater number of links for a given length and wear at each of those links. Keep loads reasonable should help with this. Fortunately this year's game should not involve a lot of pushing so managing your chain loads should be fairly straight forward.
Unread 06-01-2015, 15:55
Jeffrafa's Avatar
Jeffrafa Jeffrafa is offline
Robotics Addict
AKA: Jeff Lewis
FRC #1425 (Error Code)
Jeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant futureJeffrafa has a brilliant future
As Lee mentioned, for 2 sprockets it is pretty easy to calculate center distance. For 3 or more on the same chain, it gets quite a bit more difficult.
Dr Joe created a useful excel spreadsheet for calculating this, check out his whitepaper: http://www.chiefdelphi.com/media/papers/1598
Its not the most intuitive interface, but will let you find the appropriate spacing to avoid half-links, and get a tight chain. It also creates a plot to visualize the chain run to make sure it matches your design intent.
Team 1425 Alumnus and Mentor
I am KF7JDK - What's your callsign?
Unread 06-01-2015, 21:14
cbale2000's Avatar
AKA: Chris Bale
FRC #0703 (Phoenix)
Thank you both for your quick responses, all of this will definitely help our design.
