Go to Post i just want to say how awesome the high volume tank is. The high volume tank is 7/4 as awesome as the previous tanks. - Tytus Gerrish [more]
Unread 06-01-2015, 17:54
Edxu's Avatar
Edxu Edxu is offline
Strategy/Scouting Mentor
AKA: Edwin Xu
FRC #4476 (W.A.F.F.L.E.S Robotics)
Rookie Year: 2013
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
Possible Robot Design?
I was just thinking, since the frame perimeter rules were taken away, one could theoretically build a VEX-type robot which is basically a crate containing the robot(s) which fall out after the end of auton.
Are there any rules that specifically prevent the construction of two 3-CIM robots that are electrically/mechanically connected?
The only rule problem I can see would be G25, but that doesn't seem very relevant either.
Unread 06-01-2015, 17:59
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Possible Robot Design?
I suppose that as long as you control the robot with the same battery/roboRio/other one-of components, and have all 8 sides of your "robot" have number displays, nothing is stopping you from doing that.
Exactly what benefit are you trying to achieve from that? If I understand correctly, you're looking for something reminiscent of 2002 "minibots" which were designed to get back to the home zone for end of match points.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016) | FTC Referee (2017)
Academic Student (Forever)
Unread 06-01-2015, 18:09
Edxu's Avatar
AKA: Edwin Xu
Rookie Year: 2013
I was just considering what ways to score points, and a stacking efficiency was one of the things that I considered. If you can separately push 2-high stacks, your stacking speed would increase.
Unread 06-01-2015, 18:14
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
Rookie Year: 2014
nxtmonkeys will become famous soon enough
You could have a bot that has space for a tote inside of it (as a lift/intake/whatever) and have a mini-bot sit in there and deploy at the start of the match.
5349- the RoboEagles
You wanna have a BAD TIME?
Unread 06-01-2015, 18:33
CalTran's Avatar
Missouri S&T Senior
Rookie Year: 2010
Interesting idea. To be sure I'd say take it up with the Q&A tomorrow, but one of the first issues that comes to mind is the degree of difficulty that would come from trying to drive two separate robots that are mechanically connected.
Unread 07-01-2015, 14:24
GDB's Avatar
GDB GDB is offline
Mentor
AKA: Garrett
FRC #2403 (Plasma Robotics)
Rookie Year: 2012
GDB is a jewel in the roughGDB is a jewel in the roughGDB is a jewel in the rough
So basically you want two robots but they actually are connected but will be used for different jobs? What do you have in mind for each "robot"?
Project Manger and Build Lead of Plasma Robotics - Team 2403 - 2015 season and 2016 season
Unread 07-01-2015, 14:47
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Something like:
