Hello again!
I have another error with the CANJaguar code when enabling the robot. All of our code compiles and deploys successfully, however, when we enable the robot our driver station spits out this error Code:
Error on line 492 of CANJaguar.cpp: sendMessage at /home/lvuser/FRCUserProgram() [0x17088] at /home/lvuser/FRCUserProgram() [0x17250] at /home/lvuser/FRCUserProgram() [0x187e8] at /home/lvuser/FRCUserProgram() [0x16b64] at /home/lvuser/FRCUserProgram() [0x1d9b4] at /home/lvuser/FRCUserProgram() [0xf754] at /home/lvuser/FRCUserProgram() [0x134f4] at /home/lvuser/FRCUserProgram() [0x29f90] at /home/lvuser/FRCUserProgram() [0x30e54] at /home/lvuser/FRCUserProgram() [0xfdd8] at /home/lvuser/FRCUserProgram() [0x155b4] at /home/lvuser/FRCUserProgram() [0x1bbfc] at /home/lvuser/FRCUserProgram() [0xfee4] at __libc_start_main Code:
void CANJaguar::sendMessage(uint32_t messageID, const uint8_t *data, uint8_t dataSize, int32_t period)
int32_t localStatus = sendMessageHelper(messageID | m_deviceNumber, data, dataSize, period);
if(localStatus < 0)
wpi_setErrorWithContext(localStatus, "sendMessage");
Thanks, Drew |
Re: CANJaguar error with 2015 C++ port sendMessage
Have you updated the Jaguar to v109 firmware? Have you checked using the roboRIO webdash that the roboRIO can see the Jaguar you are trying to talk to and that the ID is what you expect?
Yeah, we have updated all of the jags to v109, however we cannot see the jags in the roboRIO panel. It only shows the PDP and the PCM. We have the roboRIO as the start of the CAN network and the terminator as one of the jags. We also have set the PDP terminator jumper switch to off, so it should be able to detect the jags after the PDP.
Thanks! I'll try that. Our meeting is over today so I don't have the robot on me at the moment. (I wish we could afford some talon srx's right now!)
![]() -Drew |
It was a wiring issue with the JAGs.
Thanks for the help. |
