Go to Post "Wow, smells like... physics" - Anna B. [more]
Unread 06-01-2015, 23:37
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
roboRIO not found
I've been having some trouble programming/debugging the RoboRIO. This is the tail end of the output I see in the console when attempting to deploy:
Code:
get-target-ip:
     [echo] Trying Target: roboRIO-488.local
Unknown host: roboRIO-488.local
     [echo]  roboRIO not found via mDNS, falling back to static USB
     [echo] roboRIO not found via USB, falling back to static address of 10.4.88.2
BUILD FAILED
C:\Users\John\wpilib\java\current\ant\build.xml:45: Assertion failed boolean test.
roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse
I can ping roboRIO-488.local successfully. I can also read the files on the roboRIO via FTP.
In Window->Preferences->WPILib Preferences, my team number is set to 488.
The roboRIO has been imaged with the v23 image (and I can confirm with the tool). I can also see and operate the robot via the Driver Station.
By plugging in the USB cable, I am able to program the robot. Also, the debug environment seems to only try connecting to roborio-488.local, and doesn't work via USB.
Any idea what's going on?
