Go to Post "So Ken Patton, Paul Copioli, and John V-Neun walk into a bar..." - JVN [more]
Unread 07-01-2015, 11:11
MrRoboSteve MrRoboSteve is online now
Mentor
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
Rookie Year: 2011
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Servo watts calculation
According to R18:
PWM COTS servos with a maximum power rating of 4W each at 6VDC
Per the Servo Industry, Servo Max Power Rating = (Stall Torque) X (No Load Speed)
I'm wanting to do the calculation for the HS-422 servo. Can someone verify my work?
Assumes 6v power at PWM port on roboRIO.
Torque T = 4.1 kg-cm = .4 N-m
Angular speed w = .16sec @ 60 degrees
Watts W = N-M / s = .4 / .16 = 2.5
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 07-01-2015, 11:53
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Servo watts calculation
You can compare to this spreadsheet. Looks like the only difference is due to rounding. http://www.chiefdelphi.com/media/papers/2751
Unread 07-01-2015, 22:31
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
It's worth noting that what the servo industry calls "power", knowledgeable people call "wrong". Divide that false rating by 4 to get the theoretical maximum power of the servo, which you can use for mechanism design.
(It's false because there exists no condition1 where a DC brush motor is simultaneously spinning at its free speed and drawing its stall current.)
1 Assuming that the motor is connected only to an electrical power source at steady state.
