Auto Powerhouse?
I believe that there will be a team that will be able to score all cans and stack all containers in auto getting 28 points everytime for their alliance
Re: Auto Powerhouse?
That really wouldn't be surprising. Elite teams always figure out how to maximize their autonomous performance. It's what makes them elite.
Yeah, it doesn't seem _that_ difficult conceptually. It would be hard to pull off due to all the sensors required and testing time needed.
1) Get your alliance partners to drive forward to get the robot set. Maybe ask them to push their cans with them. 2) Use your high-quality stacker robot to grab the yellow bins one at a time, build a stack, then scoot to the auto zone and drop it off. Tada! |
On the other hand, I think we will see an alliance that scores the container set and tote stack in auto, and claims atleast two of the center recycle containers. |
We're working on a concept that could score a CONTAINER SET on its own during auto mode. It might work, it might not. We'll have to see.
![]() That would be legal, (and useful) as Karthik pointed out in his "Karthik's Strategic Analysis" seminar which is part of Build Blitz. I hope we have a few Texas partners this year who can lasso up some Containers. <Insert Yee-Haw here> |
I think it is completely reasonable to assume that one robot can score everything in auto bar the robot set. Although I am not on a team this year, I am designing a theoretical bot (full CAD) that should be able to get the 28 points alone (I know, easier said than done).
To be completely honest, it is less about the robot and more about the strategy and working with other teams. In fact, with a perfect alliance, I foresee a robot set, container set, Tote stack, and possession of 7 of the 10 containers on the field. XXDoing this is nearly an instant win if you can get a few stacks with bins on them.XX Edit: Have to get into a Max Point mindset. Doing this will give you amble opportunity for scoring, and allows you to stack a bit lower (One 6 tote+Cont stack< Two 4 tote +cont stacks) to maximize your scoring potential. Doing this also limits the opposition to 3 stacks with containers on them (because you have the other 7). Hope this helps some teams strategize. Last edited by Cyberphil : 07-01-2015 at 13:17. |
#10
I also predict that because of unintentional interference from the other teams on the alliance they won't be getting that as often as they'd like. |
#11
Full loop back to the robot instead of loop at the end? Hold one end, winch the other, drop the held end after you've gotten the containers, winch in the rest. It's a one trick pony, but I have difficulty believing any 3 container winch system would be reusable anyways.
#13
![]() Seriously though I'm looking forward to seeing the solutions teams find to this problem. I'm guessing we will see some clever solutions including the return of tape measures on FRC robots. |
#14
Teams that have a plan of dragging containers behind them better also come up with a way to stand them back up. Generally speaking, getting 8 points in autonomous isn't worth losing a potential 90 points in tele-op.
#15
We are working on some concepts that would get the 20 points for stacking the three yellow totes by ourselves in autonomous - I am pretty certain that we'll get it. (I'll know in three or four weeks). Adding all three recycling bins into the mix makes things more interesting. I have some ideas on how we could do this, but developing them into something that works is a lower priority than fully developing the primary functions of our robot.
