Go to Post I believe that those who have a clear understanding of their capabilities, both physical and financial, and design and build within those capabilities are the teams that succeed. - Daniel_LaFleur [more]
Unread 07-01-2015, 14:48
bmxer51 bmxer51 is offline
FRC #2874
bmxer51 is an unknown quantity at this point
Referencing a variable in a text document
Last year at regionals someone showed my team how their autonomous program referenced variables that they had typed into a text document then stored it on the cRio via FTP. Could anyone explain how to program in labview to do this? I read the manual and know how to FTP to the new roborio but I don't know how to reference the text document in labview.
Basically if we had programmed the robot to go forward for 3 seconds we want that 3 to be in a text document so if its too long we can just change it to 2.9 and save the document without recompiling the code every time.
Thanks for all the help!
Unread 08-01-2015, 00:34
tcjinaz tcjinaz is offline
Tim
FRC #3853
Rookie Year: 2011
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Re: Referencing a variable in a text document
Root around for the "command-based programming" stuff. Classically, these open a file at some spot in the robot's file system, then read commands (line by line of you will) from there.
Software Mentor
3853 Pridetronics[
