Go to Post If Teflon-coated pans have a no-stick surface, then how to they get the Teflon to stick to the pans? - dlavery [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 08-01-2015, 03:32
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Re: Scissor Lifter?
Originally Posted by asid61 View Post
Why and how? This seems to be a very contradictory veiwpoint here, and I'd like to hear your thoughts. What is your experience?
We built one in 2003 stack attack and it stacked bins very nicely. The scissors lift only had to go 2 bins high max.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 08-01-2015, 09:04
sviridovt sviridovt is offline
FRC #5329 (S(A^3)S Robotics)
Rookie Year: 2012
sviridovt is on a distinguished road
Re: Scissor Lifter?
Let me just repeat every one here: NO SCISSOR LIFTS unless you want to know what hell feels like. The only time one should even consider a scissor lift is when you have to lift for small distances, with only one layer. Anything more will be waaaaay unstable.
Unread 08-01-2015, 19:39
waialua359's Avatar
Mentor
AKA: Glenn
Rookie Year: 2000
Re: Scissor Lifter?
While our team probably won't be making one, I'd bet that it's still possible to create an effective one for specific purposes.
How ironic that the best VEX robots this year all use scissor lifts, where the game requires precision and going really high.
Unread 09-01-2015, 12:59
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
Rookie Year: 2012
InFlight is an unknown quantity at this point
Re: Scissor Lifter?
A scissor lift to raise totes is probably an overly complex and likely too slow in operation compared to the alternatives.
Ideally you should want to raise the totes in an about a second or two at most.
Unread 08-01-2015, 16:56
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Rookie Year: 1999
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Scissor Lifter?
If you look at my avatar, we built one during my high school team's rookie year (1999, team 311). Took us 4-5 weeks and 2-3x the allotted weight to get it working properly. I tend to steer students away from the scissor lift, though I don't like to outright eliminate it as a possibility.
The 1999 application was before pneumatics and I think using pneumatics would make it to develop the scissor lift, but I still don't think it's worth the weight, size and complexity when other options are available.
Originally Posted by IndySam View Post
#1 No casters.
One note; team 311 went to the rubber match as the alliance captain in the finals on Einstein in 2002 with casters.
Unread 08-01-2015, 17:17
TheCrayButton's Avatar
TheCrayButton TheCrayButton is offline
FRC #3528
TheCrayButton has a spectacular aura aboutTheCrayButton has a spectacular aura about
Re: Scissor Lifter?
Our team had great success with a scissor lift in 2012. We actually won a regional with it. Here is a video of it. http://youtu.be/jFwkC_s2BAQ?t=53s
Unread 08-01-2015, 01:26
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Scissor Lifter?
Originally Posted by ShinyShips View Post
There are only two rules when designing on our team:
  1. No turntables
  2. No scissorlifts
Ours are:
  1. No Tank Treads
  2. No Scissorlifts
We did both in our first year and haven't done either since.
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 07-01-2015, 20:27
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Scissor Lifter?
No experience, except that I spend a lot of time on man-rated industrial scissor lifts.
If stability is important, scissor lifts of more than one stage should be rated as do not use. I walk from one end of a lift to the other, it sways a bit.
If simplicity is important, scissor lifts in general should be rated as do not use. (See: elevator system, pneumatic lift)
If you can't do much precision work... See the bold text above.
If you are seriously considering doing a scissor lift system, you should do the math. I've heard of engineers getting scared of that math. You need to account for all the stages, the stability, and the precision needed. It's not easy.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 08-01-2015, 07:43
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: Scissor Lifter?
Two more things that make scissor lifts hard:
1) One or both of the bottom sections has to slide across the bottom surface as it extends upward. Getting that to work smoothly with low friction and without wobbling around is tricky.
2) Powering a scissor lift without hydraulics is hard if you're lifting a decent amount of weight. When it's fully retracted, you have to supply a lot of force to get it started, because the initial angle is unfavorable. Certainly it can be done with motors, but I think it's a lot trickier than powering an elevator or an arm.
Unread 08-01-2015, 16:15
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Re: Scissor Lifter?
Thank you! We'll keep these in mind if we prototype one.
Unread 08-01-2015, 16:43
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Re: Scissor Lifter?
In our initial prototyping, we drew a number of designs on a big whiteboard for lifting the totes, including a scissor design. That image was quickly circled with red marker multiple times, and then in bold and exclaimed letters indicated as "Do Not Use!!!" I cannot tell anything else about our design (because we are still finalizing stuff) other than we will most certainly not be using a scissor lift because its incredible complexity and inconsistency. There are many more successful designs available, if you are stumped I suggest you start by looking at the various RI3D elevators and arms, they might serve you better.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
