Go to Post That's awesome. I sort of like the smaller venues. You get to know teams on a lot more personal level. - thisOrrthat [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 07-01-2015, 21:45
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Custom models for frcsim?
Haven't found any documentation to do this. Of course, haven't looked terribly hard either...
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 07-01-2015, 22:49
dawonn's Avatar
dawonn dawonn is offline
Mentor
AKA: Dereck
FRC #2586 (Calumet Copperbots)
dawonn is an unknown quantity at this point
Post Re: Custom models for frcsim?
You will probably need to make a custom Gazebo Plugin that describes your robot's kinematics and control signals. I also haven't looked to terribly deep into it myself yet, but I have worked with Gazebo quite a bit in the past.
IIRC: You can define the structure of your robot in an XML type file where you specify each joint and link in your system, then write a c++ plugin that describes how to control each joint.
Unread 07-01-2015, 22:52
virtuald's Avatar
RobotPy Guy
Right, the frcsim plugins provide generic functionality to control a joint, so ideally those are designed such that they will work with any general robot (for example, pacsim and gearsbot use the same binaries).
And yeah, I'm vaguely aware of the XML, but I'm not sure of the format, and I suspect there's something one needs to do to create the world file.. etc. I'd rather not have to reverse engineer it if FIRST has already provided tools to do these things (which, I feel like I read about them somewhere... maybe)
Unread 07-01-2015, 23:17
dawonn's Avatar
Mentor
AKA: Dereck
I haven't seen anything else provided by FIRST. It would be pretty cool if someone would crate a world model of the areana and share it on CD though, eh? Perhaps I might take a look at doing that...
The XML file is specific to Gazebo, It's not that bad once you get into it but it has a pretty steep learning curve.
Unread 08-01-2015, 09:22
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
We aren't officially supporting the addition of your own models to Gazebo. There is a plugin that was developed last summer supported by SolidWorks and OSRF and we will continue to work on it with the hope of making it available in the fall. The idea is that the model can be annotated with the sensor and actuator information for your robot, and the plugin exports the model with that information in URDF format that can be imported into Gazebo. Then a plugin for Gazebo allows the simulator edition of WPILib to talk to simulated model. Look for a beta in the spring or early summer that you can start playing with.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
Unread 15-01-2015, 15:26
jman1783 jman1783 is offline
FRC #2900 (Mighty Penguins)
Rookie Year: 1999
jman1783 is an unknown quantity at this point
All,
I will echo Brad - this is not yet supported, although it IS possible for enterprising teams. I built up a very simple FTC robot this way from a team's CAD assemblies, but it wasn't linked to the WPIlib code, which is more tricky.
Brad,
It's difficult to do at the moment, but could we throw together best practices for conforming to the robotmap.xml file, and let teams use the old CAD exporter, or the alpha version of the new exporter?
"Just remember - whether you think you can or you think you can't, you're right." -Stewart Gilligan Griffin
Unread 19-01-2015, 12:49
AKA: Brad
Originally Posted by jman1783 View Post
All,
We'll try to post something for people to play with, but with the understanding that it is not yet finished. Maybe sometime this week.
Brad Miller
