Go to Post When it comes to FIRST (you've all heard the cliche) -- we're all winners. When it comes to the competition: to the engineering design challenge, we're NOT all winners -- some solutions are better than others. - JVN [more]
Unread 08-01-2015, 00:13
Caitlinnnnn99's Avatar
Caitlinnnnn99 Caitlinnnnn99 is offline
Why does bag come so soon?
AKA: Caitlin T-HB
FRC #3250 (Kennedy Robotics)
Team Role: Mechanical
Rookie Year: 2014
Caitlinnnnn99 will become famous soon enough
Help with Gyro
Hello, we are using the ADXRS453Z along with the roboRIO and the numbers (angle) we are getting back is just continuously increasing (into the negatives), we are using the new roboRio Labview example, and was wondering if anyone can help with making the gyro read the angle properly. That is, instead of reading and adding what seems to be the gyro rate, to read just what the gyro's real angle is.
Also, we are very sure that we wired it correctly, because we did it according to the picture in the lab view example.
Any help would be much appreciated. Thanks.
Unread 08-01-2015, 00:29
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Help with Gyro
The ADXRS453Z is a digital gyro. The LabVIEW gyro library is for an analog gyro. You will have to write your own driver and integration routine to use the ADXRS453Z.
Unread 09-01-2015, 20:45
AKA: Caitlin T-HB
Rookie Year: 2014
Re: Help with Gyro
Thanks Joe,
The new labview 2015 has provided us with an example code for this specific sensor using SPI Vi's. We've put this example program into our robot program and have also tested with just the example program and the results are still the same: an increasing number for the angle.
We need some help on changing this to where we read the actual angle of the gyro's position. Not a constantly increasing number, even when the gyro isn't moving.
Also, in the program it seems to be adding the rate of angular change?
But the thing is when we leave the sensor still it continues to rise in "angle".
Why would it continue to increase even when the gyro is still?
I have attached pictures of the example code we are using.
Name:	Gyro Example Block Diagram.PNG
ID:	17789  Click image for larger version
Name:	Gyro Example Begin Front Panel.PNG
Unread 09-01-2015, 23:57
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Rookie Year: 2012
Team3266Spencer is an unknown quantity at this point
Re: Help with Gyro
I'm not familiar with the gyro or LabView but on page 7 of this data sheet there is some data for drift with this gyro. Most gyros "drift" over time, meaning 0.2 degrees may be incremented every second even when the gyro is stationary.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 11-01-2015, 00:19
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Rookie Year: 2011
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
Re: Help with Gyro
Sorry that this post is a little out of place, but what is your application of the gyro in this years game? Autonomous or teleop? I went over the use of a gyro with a few members of my team and they seemed to deem it unnecessary. Normally I would agree, (our team is not particularly known for our programming prowess). I am interested this year because of the need to use every second available, my team plans on using autonomous to set ourselves up for teleop scoring. The more accurately we know our robot's position the faster we can move in autonomous, faster = higher score.
What do you guys see as the practical applications for gyroscopes in this years game? At what stages in the game? Is there any specific gyroscope you would recommend? Thanks in advance.
Unread 11-01-2015, 23:38
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Re: Help with Gyro
A gyro is required for field-oriented drive configurations. Think of it like this: If I push the joystick forward, the robot will always drive forward, regardless of where the "front" of the robot is. This feature makes it a LOT easier for inexperienced drivers (and mentors) to drive the robot! It's also essential for drive systems which can "strafe".
On a mecanum drive system, when coupled with encoders, the gyro makes programming an autonomous routine very precise! As a general rule, the more accurate data you have available to your drive system, the more precise your execution will be!
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 13-01-2015, 15:25
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
Rookie Year: 2011
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Re: Help with Gyro
Originally Posted by Caitlinnnnn99 View Post
Thanks Joe,
All a Gyro will ever give you is a roll rate for each axis. The key is that it is a rate not a heading. The thing you need to look for is gyro integration. This is the process of constantly adding in how fast you were turning for the last time period that you were measuring to your current heading. As for the reported movement even when the gyro is still, you need to calibrate to get rid of the false movement. Read http://www.chiefdelphi.com/forums/sh...ight=Best+Gyro it talks about a lot of this. Furthermore I think that if you decide not to use the WPI libraries you will need a co-processor (Arduino) to read the gyro, calculate the heading, and transmit it to the RIO via UART or another coms method.
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
