Go to Post Being inspired is a lot like learning, not everybody does it the same way. - Jay Trzaskos [more]
Unread 08-01-2015, 11:57
flamespinner flamespinner is offline
Head web designer
FRC #3926
Team Role: Webmaster
Rookie Year: 2012
flamespinner is an unknown quantity at this point
CAN Help
How do you program CAN for Jags and Talons? I have never used CAN before, and i'm completely lost. And It dosn't help that I am new to programming anything past basic Pneumatics and RobotDrive. Could Someone please help me?
Unread 08-01-2015, 12:06
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
Re: CAN Help
Here's the FRC screensteps. I would just search using the search bar for programming help...
http://wpilib.screenstepslive.com/s/4485
Also checkout the Talon SRX software ref manual for SRX specific examples....
http://www.crosstheroadelectronics.c...ol_system.html
Unread 08-01-2015, 12:07
BradAMiller BradAMiller is offline
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
Re: CAN Help
There are two CAN Talon SRX sample programs included with the plugins that you should look at. One, "CAN Talon SRX" does a simple voltage controlled example. The other more interesting sample, "CAN Talon SRX PID" uses PID control in the Talon to control a motor from a potentiometer input that you might use, for example, to make an elevator that would lift game objects to a particular level.
To get those samples from Eclipse, select New Project..., then "Example Robot C++ Project", then choose one of the two samples described above.
These are both very simplified programs to show the basics of using the Talon SRXs and not how you might write a complete much more complex program. There are a bunch of other samples and ScreenSteps documentation to help with that.
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
