Go to Post My experience in FIRST has taught me that, whatever you do, make sure that no single failure can eliminate half your drive system.[...] The worst feeling in the world is having your robot driving around in circles when there is critical business to be done on the playing field. - Andrew [more]
Unread 01-08-2015, 06:49 PM
nick818 nick818 is offline
AKA: Nicholas Currault
FRC #2840 (Blue Tide)
Rookie Year: 2014
nick818 is an unknown quantity at this point
Joystick GetRawButton not working
We're using a Saitek X52 joystick. GetRawAxis works fine, but GetRawButton and GetTrigger do not.
We've tried several different buttons on this joystick. Some were always true, but others were always false.
This is only a problem with this joystick. When we tried with a Logitech ATK3, it worked.
Unread 01-08-2015, 06:54 PM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Re: Joystick GetRawButton not working
What do the button indicators do on the DS USB tab? What do they do in the Windows Joystick/Gamepad properties?
Unread 01-08-2015, 07:31 PM
Rookie Year: 2014
They light up when the button is pressed.
Unread 01-10-2015, 02:37 PM
Domo Arigato Domo Arigato is offline
Domo Arigato is an unknown quantity at this point
Is anyone else having this issue?
Unread 01-26-2015, 09:26 PM
kbocheltree kbocheltree is offline
FRC #4122
kbocheltree is an unknown quantity at this point
We are using Logitech ATK3 Joysticks and are having problems seeing the GetRawButtons in the code. We pulled code we used last year for handling the buttons and it is not working now. GetX, GetY and GetZ all work, but am not seeing the GetRawButtons.
Am writing debug code tonight to see what is happening.
Unread 01-28-2015, 07:33 PM
FRC #4122
Added debug statements and problem was with other section of code. Added code to show button presses on SmartDashBoard. So GetRawButton is working fine for Logitech ATK3 controller.
Unread 01-29-2015, 05:57 PM
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Thanks for updating the thread with results!
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 01-31-2015, 09:29 PM
sau sau is offline
FRC #2220 (Blue Twilight)
Rookie Year: 2012
sau is an unknown quantity at this point
YES!!!! Our team is also having problems with programming our Saitek X52. We have tried for the last two weeks to get our joystick to work. getRawAxis() works fine, but getRawButton() does not. We have not tried getRawTrigger(). We have also tried DriverStation.getInstance(), and we can pull the axis value directly from the driverstation, but are not able to with the buttons.
Our driver station does seem to recognize the buttons being pressed, as they light up when pressed, but they always return either a true or a false boolean.
We have tried the (more or less) same code with our Xbox controllers, and the buttons do work. Maybe it is just impossible to use the X52's?
