Go to Post The moral of this story: A healthy respect for the customer, dedication to your job, and a positive outlook can make even the most trivial and monotonous job into a wonderful experience. - Molten [more]
Unread 08-01-2015, 21:16
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Rookie Year: 2012
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
CAN for Pneumatic Control Module
Does anyone know of any kind of guide to programming the Pneumatic Control Module in labview?
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 08-01-2015, 23:10
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: CAN for Pneumatic Control Module
As long as you have the PCM on the CAN network (somewhere between the RoboRIO and the PDP with the termination resistor set to on), the compressor will just work - no coding it to turn on. The compressor and pressure switch attach directly to the PCM and it will control it all by itself. The most you will have to do is code your solenoids.
Check out this article (under the Compressor section) for a bit more info on what changed this year to control pneumatics.
I'm right 90% of the time, so why worry about the other 3%?
Unread 08-01-2015, 23:15
AKA: Josh Patterson
Rookie Year: 2012
Awesome, ill make sure the programmers see this. Thanks.
2016-Present FTAA
