pic: Test Board with New Control System and Talon SRXs
Re: pic: Test Board with New Control System and Talon SRXs
Are the 4 bearing blocks in the corner the Plastic Clamping Bearing Blocks? (P/N 217-4155)
If so, how have they held up? Have you had any issues with them? |
Could you possibly go into detail in how you got your usb camera feed working and what camera are you using? I'm having troubles getting a PS3 Eye camera working with a similar test bed setup.
Then in your code you need to insert the following lines in the initialization of the Robot (Assuming you are using Java or C++): Code:
CameraServer server = CameraServer.getInstance();
server.setQuality(50);
server.startAutomaticCapture("cam0");
