Go to Post I guess I should read the manual. - r_towle [more]
  #16   Spotlight this post!
Unread 16-01-2015, 14:52
LamboRobo's Avatar
LamboRobo LamboRobo is offline
AKA: Karthik Vishwamitra
FRC #4550 (Something's Bruin)
Rookie Year: 2013
LamboRobo is an unknown quantity at this point
Re: [Ri3D] Team Indiana Powered By AndyMark (And Corn)
Are you using the 4-inch wheels that came with the kit of parts? And are you using a west coast drive (with the center wheels lower)? Thanks guys, and good work on that bot!
  #17   Spotlight this post!
Unread 16-01-2015, 15:34
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Rookie Year: 2007
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
We just used the standard KOP wheels and chassis in a long configuration. The center wheel is dropped by .140".
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
  #18   Spotlight this post!
Unread 16-01-2015, 15:43
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
For future reference, dropping the center wheels is not what makes something a "West Coast Drive" (it is merely one portion of it).
http://wiki.frc1716.org/wiki/index.php/West_Coast_Drive
  #19   Spotlight this post!
Unread 20-01-2015, 16:00
jds2001 jds2001 is offline
AKA: Jon Stanley
FRC #4263 (CyberDrgaon)
Rookie Year: 2013
jds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud of
My question was around the gearbox. I'm not familiar with the Modulox gearbox, are there one or two of them (I see two CIM's on the back, so I'd assume two??). The output drives a cam that drives a chain?
  #20   Spotlight this post!
Unread 20-01-2015, 19:22
PurpleInk PurpleInk is offline
Mrs. BoilerMentor
AKA: Betsy Baxter
FRC #1747 (Harrison Boiler Robotics)
Team Role: Teacher
PurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant futurePurpleInk has a brilliant future
Two 2.5" CIM motors drove the modulox gearbox. We used a two-slot modulox gearbox. The gearbox had a custom output shaft (8mm with 2mm keyway) that went into a RAW box. Then, a custom hex shaft was machined to interface with two bevel boxes (one at each side of the robot). The gearbox was up-driven 2:1 to offset the bevel box's 2:1 reduction.
FIRST Team 1741 - Student 2005 - 2007
FIRST Team 1741 - Mentor 2007 - 2012
BoilerMentor Asks Me to Join His Alliance
FIRST Team 1747 - Mentor 2012 - Present
Ri3D Team Indiana - 2015 - Present
  #21   Spotlight this post!
Unread 09-02-2015, 22:23
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
Trapped under a pile of MECANUMS :P
AKA: @doctorfogarty
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
How thick and what material were your plastic fingers? I'm going to go back through your videos to see if you mention, but we're using some 3/8 polycarb fingers and we just cant seem to get them to bend to allow the green container to squeeze in even when we push it up against the wall.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
  #22   Spotlight this post!
Unread 10-02-2015, 16:20
ruralrobotics ruralrobotics is offline
Rawhide Robotics
FRC #5657 (Rawhide Robotics)
Team Role: Coach
ruralrobotics will become famous soon enoughruralrobotics will become famous soon enough
We were also wondering what material you used for the plastic fingers. Polycarb? How thick and did you use heat to bend them?
  #23   Spotlight this post!
Unread 10-02-2015, 17:09
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Hey everyone!
I forgot to look at the fingers today while I was at work, but if I remember correctly they were 1/8"-3/16" thick. Also, make sure you use a heat gun on low and give it a lot of passes. To quote our Twitter page, "like a crock pot of corn, low and slow" to ensure they don't bubble and become brittle. You will also want to be sure to have a hard straight edge to bend against to ensure your bends are how you would like them to be.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
