Go to Post No Firsting way! - Tytus Gerrish [more]
Unread 09-01-2015, 20:02
SquishyIce's Avatar
SquishyIce SquishyIce is offline
FRC #1405 (Finney Falcons)
Team Role: Electrical
Rookie Year: 2012
SquishyIce can only hope to improve
LifeCam 3000 FPS Limit
Hey everybody,
We just got our LifeCam 3000 working tonight, and we noticed that there seems to be a limit of 10 FPS. Is there any way to raise this limit? Just so you know, we're using Java.
Unread 09-01-2015, 20:05
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: LifeCam 3000 FPS Limit
I believe there are some fixes in work for the camera libraries that will make it more efficient and have higher frame rates.
Unread 09-01-2015, 20:52
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
Rookie Year: 2010
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Correct. We're hoping to get these out sometime next week, we're in the testing phase for the improvements now.
Unread 10-01-2015, 11:20
SquishyIce's Avatar
Rookie Year: 2012
Another quick question, we have a circle in the top left corner of our camera feed in the dashboard. Is there a way to remove this circle, or is this some sort of feature?
Unread 10-01-2015, 12:26
Rookie Year: 1997
It sounds like you are using the Intermediate Vision example, which shows how to make the robot process the image and send the processed image. It does this by drawing a circle. If you just want view the camera images on the dashboard, you should look at the Simple Vision example, which uses automatic capture in the background.
Unread 16-01-2015, 18:26
SquishyIce's Avatar
Rookie Year: 2012
Sorry for bringing this thread back up again, but have the updates to the API been released yet?
"MAKE IT WORK, DAVID"
Unread 17-01-2015, 01:31
Rookie Year: 1997
Take a look at today's team update.
Unread 17-01-2015, 03:00
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Team Role: Mechanical
Rookie Year: 2013
Hehe. I read this as something like "Lifecam has a 3000 fps limit" and I was wondering why anybody would complain about that. Seemed like plenty of fps to me.
Unread 17-01-2015, 08:55
SquishyIce's Avatar
Rookie Year: 2012
If only...
Unread 17-01-2015, 21:58
The limit is 30 fps. In order to get that many, you will need to set the camera frame rate. You will need to modify the exposure or provide enough light for the auto exposure. And you'll have to have efficient code doing the Gets and processing.
If your code takes longer than 33ms, you cannot keep up with the camera, and it will start dropping frames.
Greg McKaskle
Unread 18-01-2015, 10:01
SquishyIce's Avatar
Rookie Year: 2012
Tested all this new stuff out yesterday, works great! Thanks for all your help, everyone.
