Go to Post Genius is one percent inspiration and 99 percent perspiration, which is why engineers sometimes smell really bad. - Koko Ed [more]
Unread 10-01-2015, 11:16
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
Question Eclipse C++ not accessing WPILib
Our team recently decided to transfer to C++ from Java and transfer to Eclipse, so we do not have the WPILib fully installed. We have tried searching and we have gone to screenstepslive, but we haven't found anything which seems to let us use the library. At present, we are unable to use things like "=new Joystick", "=new Command", and such, with the last word throwing an error. We are running Windows computers, if it is significant. Three (or possibly one, depending on how sub-questions work) questions:
1) Are we warranted in our belief that WPILib is likely not fully downloaded and/or not working?
T-->1a) If so, where should we go to successfully download it or find steps on how to make it work?
F-->1b) If not, what is the most likely culprit? Can you provide some tips on solving it?
Thank you for helping!
Unread 10-01-2015, 12:46
TechWarlock TechWarlock is offline
Programming Dude
AKA: Jacob
FRC #1396 (Pyrobots)
Rookie Year: 2011
TechWarlock is an unknown quantity at this point
Re: Eclipse C++ not accessing WPILib
http://wpilib.screenstepslive.com/s/4485/m/13810 if you follow this link itll take you to the wpilib screensteps, Under setting up the development environment you should find everything you need
