Go to Post I never had any doubt; good people who do good quality work will always prosper. - Gary Dillard [more]
Unread 10-01-2015, 11:31
asnell16 asnell16 is offline
FRC #3323
asnell16 is an unknown quantity at this point
Unhappy My RoboRio needs a doctor
Hello I am a leader of Potential Energy team 3323 in NH. We received a RoboRio in our KOP this year. We then looked up the schematics for wiring it in and made a prototype board. the RoboRio is receiving 12v of power with a 10amp circuit breaker. This seems to be a sufficient amount of energy but when we turned it all on we waited about 30 seconds and then our status light came on. After that it flashed 2x repeatedly. Now we know this means something is wrong with the software so we are going to try re-imaging it. However, the power light refuses to go on. We are all very confused at how we are getting no power yet the status light works. Is this a problem of needing it re-imaged or what? All of our programmers and electrical members are confused as well as our mentors no one knows what could be wrong. If you have any suggestion as to how we may be able to get our power light to work we would be greatly appreciated.
Unread 10-01-2015, 11:56
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: My RoboRio needs a doctor
Call NI Support at 866-511-6285 between 1 PM CST and 7 PM CST on Monday.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 10-01-2015, 12:07
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Rookie Year: 2012
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
1058 is in the same process right now. If we get it to work I will let you know so we can help you out.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 10-01-2015, 12:47
Qmcdonn Qmcdonn is offline
FRC #2374
Qmcdonn is an unknown quantity at this point
Did you make sure that you connected the PDP to the RoboRIO through CAN? I'm pretty sure that the PDP needs to be connected via CAN For it to work. Also make sure that you put the 10 and 20 amp fuses in the PDP.
Unread 10-01-2015, 13:32
FRC #3323
Yes we did make sure we also connected the PDP through the can ports though we don't know if it is necessary, and we did put the 10 and 20 amp fuses in.
Unread 11-01-2015, 12:53
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
Rookie Year: 2011
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
In order for the RoboRIO to work you do not need to have it wired via CAN. The PDP can function fine without any can interfacing.
Also make SURE the 10 amp and 20 amp fuses are in their respective slots - the 20 amp fuse on the left giving power to the PCM and VRM, and the 10 amp fuse on the right for the RoboRIO power - see image below
The RoboRIO should be plugged into the CONTROLLER POWER slot with 18 - 22 wire guage.
Unread 11-01-2015, 12:57
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
You followed these directions right?
https://wpilib.screenstepslive.com/s/4485
Unread 11-01-2015, 15:06
FRC #3323
emileh3467,
We currently have wired it this way. When it did not work we tried connecting can as well. and it still didn't work.
Conor Ryan,
Yes we also followed these directions.
Our members just tried re-imaging the RoboRio and it still doesn't respond or work correctly. We will call for support Monday. Thank you to everyone that gave suggestions and advice.
Unread 11-01-2015, 15:52
EmileH's Avatar
AKA: Emile Hamwey
Rookie Year: 2011
asnell16,
Have you tried looking at the RoboRIO manual and its LED indicator section?
Confirm your PDP is outputting a proper 6.8-18V output through the CONTROLLER PWR port with a MultiMeter if you get a chance.
Unread 11-01-2015, 15:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
On thing that might help, is to post a couple of clear, large pictures of your electronics setup, so we can see if the wiring is right. It's easy to connect something to the wrong place, without realizing it. I know because I've done it.
If you get some more folks to confirm that it's all wired correctly, you can rule that out.
Unread 12-01-2015, 07:36
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
The CAN will be used for logging PDP data, hence the robot rule requiring that CAN be connected to the PDP. It is not needed for operation of the RoboRio nor the PDP.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 10-01-2015, 13:34
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Originally Posted by asnell16 View Post
Turned it all on we waited about 30 seconds and then our status light came on. After that it flashed 2x repeatedly....However, the power light refuses to go on.
This sounds very odd indeed. Your power LED is not lit, yet the status LED is flashing? Sounds like you are in fact getting power, but the power LED may not be functioning properly.
Can you proceed with the SW update?
Unread 10-01-2015, 13:50
AKA: Chris Rake
no team (Athena)
And one more thing - is your power plug all the way seated in the roboRIO power socket and screwed down? Doesn't explain the power LED not on, but the status light should light up shortly after you apply power. The 30 second delay is suspicious.
Unread 10-01-2015, 13:55
FRC #3323
Possibly, currently we are re-imaging it and after that we will see if it still functions without the power LED. Also yes if was properly screwed in. The 30 second delay was for the first time we gave it power after that the status light came on almost immediately.
  #15   Spotlight this post!
Unread 11-01-2015, 11:30
BrendanB BrendanB is offline
AKA: Brendan Browne
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
3323 did you guys get your RIO working? As far as I know our programming/electrical team had a smooth transition to the new system. Let us know if we can help you guys out.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
