Go to Post yes, we've gone over every possible idea multiple times. No, we're not going to stop. Welcome to FIRST. - logicalyrandom [more]
Unread 10-01-2015, 13:09
iambujo iambujo is offline
Mentor
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
PDP LEDs not lighting
Hello, we are getting started with the new control system. Things seem to be working OK with the power subsystem, yet the STAT and COMM LEDs are not doing anything at all. The manual says that means "Device is NOT powered". We have the termination jumper set to ON and at the end of the PDP is at the end of the CAN bus.
When we power on the main breaker the bridge and roborio power up, code can be deployed, and motor controllers power (in idle). So i think the PDP is functioning right. It just seems light a status issue.
Is there a firmware update that we need to do to the PDP, or do you think our PDP is just bad out of the box? I've only seen mention of PDP firmware updates in Beta tester documentation.
Thanks
Unread 10-01-2015, 19:55
joeyoravec joeyoravec is offline
FRC #1250 (GatorBots)
Rookie Year: 2013
joeyoravec is an unknown quantity at this point
Re: PDP LEDs not lighting
+1. Ours was working on kickoff day. We tried it again today, and now it's behaving the same as yours.
According to the manual it's "not receiving power" which is untrue. I think it's broken. Just sent an email to CTE tech support, and watching this thread.
Unread 10-01-2015, 20:17
Adamz_'s Avatar
Adamz_ Adamz_ is offline
Who wants coffee?
AKA: Connor Adams
FRC #4519 (Kings Mechavaliers)
Rookie Year: 2013
Adamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to behold
Ours is doing the same thing, and is still working properly.
2016 North Bay Regional Finalists
2016 Greater Toronto Central Regional Semi-Finalists
2015 Windsor Essex Great Lakes Regional Quarter-Finalists
2014 Windsor Essex Great Lakes Regional Semi-Finalists
2014 Waterloo Regional Quarter-finalists
2013 Waterloo Regional Highest Rookie Seed
2013 Waterloo Regional Rookie All Star Recipient
Unread 10-01-2015, 20:25
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The status lights have no impact on the use of the PDP for simple power distribution.
The lack of lights indicate that the Monitoring/CAN circuitry are not receiving power.
That's only a problem with the current monitoring or CAN communications necessary to retrieve the monitoring and fault status of the PDP.
Unread 10-01-2015, 20:44
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
It's a (presumed) problem if you want to compete because R61 says the PDP CAN interface has to be connected. I doubt a non-functional CAN interface would meet the intent of the rule.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 10-01-2015, 21:21
Mentor
FRC #2729 (Storm)
Thanks, please let us know what they say, I'll contact them too to document the failure. This was the case from the very first power up for our unit.
I just checked and the PDPs are out of stock, and we only have one. Ours is bad out of the box I believe. Hopefully the fix will just be firmware.
Pertaining to the inspection requirement for functioning CAN on the PDP, if you can't buy them and they are bad out of the box, what can you do...? I'm assuming they'll replace faulty units and get back in stock during the build season, but if not that would be a show stopper.
Unread 10-01-2015, 22:58
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
Rookie Year: 2011
jimbo493 is on a distinguished road
Is it possible that your CAN network is not wired correctly? I am taking a shot in the dark, but if it isn't maybe the LEDs don't power. Also, maybe you have a really low battery?
Unread 10-01-2015, 23:01
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
While this isn't immensely helpful right now, in past years, the Spare Parts booth at the regionals tended to have, well, spare parts. I think they usually had one or two control system replacements. (In the past that would be IO Boards, maybe a PDB, etc...)
Like I said, that doesn't help this early in the build season, but at least if it happens at competition, and your team doesn't have any spares, and you can't fix the issue, you have that as a backup (maybe).
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 10-01-2015, 23:32
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I wouldn't make any assumptions about availability of spares or turnaround times without contacting Cross the Road Electronics http://crosstheroadelectronics.com/contact.html
Unread 12-01-2015, 18:17
Rookie Year: 2013
Update -- we retested. The PDP seems to work (LEDs turn on, CAN works) below about 11.5v, and seems to fail (LEDs turn off, no CAN) above about 12.0v.
We're hooking it up to a variable DC power supply to further characterize. No response from Cross the Road Electronics yet.
Unread 12-01-2015, 19:13
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond repute
I don't think the cause is related to specific voltage. I just grabbed a PDP off the shelf and it seems to maintain LED functionality as I sweep the voltage 0 to 15 and back.
If anything, perhaps the smart module has intermittent contact with the rest of the PDP. If you press down on the Weidmuller CAN connectors, or press down on the LED light pipes, does the smart module suddenly come back (LEDs become illuminated again)?
If anyone else is seeing this symptom feel free to contact us at support@crosstheroadelectronics.com.
Joey, I just replied to your email. Looks like I'm not far off from where you guys are located.
Unread 16-01-2015, 20:06
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
Rookie Year: 2010
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
We're having the same issues right now. I emailed Cross the Road (haven't heard back yet) and I opened it up.
Looking at the picture (attached), I see some burnt component. Maybe that's the issue?
Anyway, the PDP still provides power, but the CAN bus looks shot.
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 17-01-2015, 17:22
Mentor
FRC #2729 (Storm)
Update, CTRE sent us a replacement and we will ship the faulty unit Monday. New unit LEDs looked good. Hopefully we get an update on the failure and if there is anything we (FRC community) need to look out for or avoid.
