Go to Post The students that I have known in FIRST over my 8 years of involvement have been far more inspired by the competition and some of the jaw dropping creations of "elite" teams than by anything that we made ourselves. - MattB703 [more]
Unread 10-01-2015, 14:09
VD3626 VD3626 is offline
FRC #3626
VD3626 is an unknown quantity at this point
Robot Builder Generating Code with Errors in it
I generated this code in Robot builder and then imported it into eclipse and hit build. The Code had errors in the robot.h file and the motor.h file (motor.h is in the subsystem folder as the only system I am currently trying to test)
robot.h:
Code:
// RobotBuilder Version: 1.5
// This file was generated by RobotBuilder. It contains sections of
// code that are automatically generated and assigned by robotbuilder.
// These sections will be updated in the future when you export to
// C++ from RobotBuilder. Do not put any code or make any change in
// the blocks indicating autogenerated code or it will be lost on an
// update. Deleting the comments indicating the section will prevent
// it from being updated in the future.
#ifndef _ROBOT_H
#define _ROBOT_H
#include "WPILib.h"
#include "Commands/Command.h"
#include "RobotMap.h"
#include "LiveWindow/LiveWindow.h"
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=INCLUDES
#include "Commands/AutonomousCommand.h"
#include "Subsystems/motor.h"
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=INCLUDES
#include "OI.h"
class Robot : public IterativeRobot {
public:
	Command *autonomousCommand;
	static OI *oi;
	LiveWindow *lw;
	// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
	static motor* motor;
	// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
	virtual void RobotInit();
	virtual void DisabledInit();
	virtual void DisabledPeriodic();
	virtual void AutonomousInit();
	virtual void AutonomousPeriodic();
	virtual void TeleopInit();
	virtual void TeleopPeriodic();
	virtual void TestPeriodic();
#endif
In line 33:
Code:
I get the error message: declaration of 'motor* Robot::motor' [-fpermissive]
motor.h:
Code:
#ifndef MOTOR_H
#define MOTOR_H
#include "Commands/Subsystem.h"
#include "WPILib.h"
 * @author ExampleAuthor
class motor: public Subsystem {
private:
	// It's desirable that everything possible under private except
	// for methods that implement subsystem capabilities
public:
	SpeedController* talon;
	motor();
	void InitDefaultCommand();
#endif
In line 22:
Code:
I get the error message: changes meaning of 'motor' from 'class motor' [-fpermissive]
I can tell that these errors are related and that if I resolve one it will probably resolve the other as well but I do not understand what is wrong and do not know what to do. Any help is appreciated.
Unread 10-01-2015, 16:25
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Robot Builder Generating Code with Errors in it
RobotBuilder was designed with the naming conventions delineated here: https://wpilib.screenstepslive.com/s...s#!prettyPhoto
In particular, since your motor class is lower case rather then first letter upper case, it's trying to declare an instance variable with the same name as the class. Delete the motor.cpp and .h and change your subystem name to Motor and clean and rebuilt and it should work.
In general, motor is probably not a good subsystem name. It should be tied to something unique and memorable piece of your robot, like DriveTrain, Arm, Stacker, or something like that. More ideas here: http://wpilib.screenstepslive.com/s/...ed-programming
Unread 10-01-2015, 17:53
FRC #3626
Thank you that fixed it.
