Go to Post OooooohhH! OOOOooohh! Can I start the 2009 thread yet? Huh? Can I? Can I? - dlavery [more]
Unread 10-01-2015, 15:15
qdawg22 qdawg22 is offline
FRC #0422
qdawg22 will become famous soon enoughqdawg22 will become famous soon enough
MSP430 LaunchPad Energia Connectivity Error
While using Energia with the KOP LaunchPad, we weren't able to select the board's serial port. Has anyone else run into this problem? Any advice to help us solve this?
Thanks!
Unread 10-01-2015, 18:30
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: MSP430 LaunchPad Energia Connectivity Error
To program the device you don't need to select the serial port, only if you want to monitor the serial port output.
You do have to select the proper board (msp430f5529 25MHz), and if you do want to use the serial port monitor you have to select the serial port for the "MSP Application UART1".
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 10-01-2015, 21:18
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Energia is a nice simple IDE for use with the LaunchPad. Unfortunately, it will not help you much if trying to modify the code used to configure it as a Gamepad.
Here is a quote from the "MSP430 LaunchPad Operator Interface for FIRST Robotics Competition" web page.
Q. Can I use something other than Code Composer Studio to code the LaunchPad?
A. Yes, there are several third party programs and compilers available. If you are more familiar with the Arduino environment, the LaunchPad has an equivalent environment called Energia, however the libraries in Energia do not currently have support for USB HID devices, so you cannot modify the Gamepad firmware in Energia.
If you just want to use the LaunchPad as a custom "GamePad", just use the GamePad tool supplied with the software update provided at the time of Kickoff.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 10-01-2015, 21:21
Happy Birthday! Ben Wolsieffer Ben Wolsieffer is offline
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Rookie Year: 2011
Ben Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud ofBen Wolsieffer has much to be proud of
If you want to create an HID device that's a lot easier to modify get the 16Hertz Leonardo++ that was given as a voucher in the KOP. We got ours and were able to setup custom firmware to make it appear as an HID device.
2016 North Shore District - Semifinalists and Excellence in Engineering Award
2015 Northeastern University District - Semifinalists and Creativity Award
2014 Granite State District - Semifinalists and Innovation in Control Award
2012 Boston Regional - Finalists
