Go to Post I don't fully buy into the 'we're all winners' concept. That is a broad statement that doesn't really say much. How did we become all winners? What did we do to become winners? Pay an expensive registration fee and participate in a robotic competition? - JaneYoung [more]
Unread 11-01-2015, 16:07
Nick Nevarez Nick Nevarez is offline
FRC #5125
Nick Nevarez is an unknown quantity at this point
Can you use the secondary pressure regulator instead of the primary?
I was trying to put the pneumatic system together and happened to not have a primary pressure regulator. I had gone to andymark.com and did not see it there. so i am asking can you use the secondary pressure regulator instead of the primary?
Unread 11-01-2015, 16:22
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Can you use the secondary pressure regulator instead of the primary?
R71 “Working” air pressure on the ROBOT must be no greater than 60 psi and must be provided through one primary adjustable,
relieving, pressure regulator, relieving, pressure regulator.
and the blue box says:
Norgren regulator P/N: R07-100-RNEA or Monnier P/N: 101-3002-1 recommended.
Which sounds to me like they have a typo but if the "secondary" regulator you have meets the 125 psi requirement, and is a relieving pressure regulator, it should be ok. Keep in mind that I'm not the Q&A.
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You can use any pressure regulator, provided it meets the R71 and R66G specs. FIRST has helpfully recommended a couple of regulators, but does not require their use.
I would also point out that AndyMark does have the Norgren pressure regulator. http://www.andymark.com/product-p/am-2020.htm
Also, a secondary pressure regulator is generally used after the primary regulator to further restrict pressure if one or more components cannot handle the pressure coming off of the primary regulator.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
